compresion question
Old Aug 20, 2005 | 01:44 PM
srsjuju's Avatar
srsjuju
Default compresion question
Does any one know the stock compression in a 85 vette
Not the compression ratio but what the compression test should show per cylinder
Old Aug 20, 2005 | 01:49 PM
Morley's Avatar
Morley
Its not so much what the cylinder pressure is as much as all 8 should be very close to each other in pressure readings.
Figure around 110 psi for a healthy engine..anything below 90 and I'd start to worry.
Old Aug 20, 2005 | 01:57 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Generally even w/ a maximum of + or - 10% variation. This along with no obvious wear problem symtoms indicates a reasonably healthy engine.
Oh and get some temperature in the engine before running the test.
Old Aug 20, 2005 | 11:04 PM
kopbet89c4's Avatar
kopbet89c4
For me so far, I am about 150 psi +/- 5 psi on all cylinders. Leakdown test from the radiator looks also good. I'd pressurize the cooling system and see how long the system holds pressure. If it loses pressure, I'd be worried!
Old Aug 20, 2005 | 11:38 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I tested at 185-195psi on my 85. As mentioned, there is no magic number. Depends on lots of things, starter condition, battery condition, engine temp....
Also, check the guage while you crank, see how many turns it takes to get to full pressure.
Old Aug 20, 2005 | 11:41 PM
kopbet89c4's Avatar
kopbet89c4
5, at least.
Old Aug 21, 2005 | 09:52 AM
Pete K's Avatar
Pete K
Be sure to hold throttle wide open when you crank it.
Old Aug 21, 2005 | 12:33 PM
redwing76's Avatar
redwing76
Also test for leak down.
To compresion question
