Cracked Heads
Old Aug 22, 2005 | 01:50 AM
wgc_3's Avatar
wgc_3
Default Cracked Heads
Ladies, and Gents,
I think I cracked my heads not one but both on my 91, anyone know of a place I can get cheap pair of new heads??
Thanks,
Bill
Old Aug 22, 2005 | 12:15 PM
kize's Avatar
kize
New, Cheap and Corvette? These words are not synonymous!
Old Aug 22, 2005 | 12:20 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I guess it depends on what you mean by "cheap". The L98 (unlike the LT1) will accept almost any SBC heads.
I'm also curious as to how you managed to crack both.
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
If you are willing to go with used heads, I'm sure there are several guys on this forum who have a pair sitting on a shelf in the garage.
Just put out the word here or in C4 Parts.
Larry
code5coupe
Old Aug 22, 2005 | 02:56 PM
LD85's Avatar
LD85
Now is the time to go aftermarket
Old Aug 22, 2005 | 04:26 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Ron at Fox Lake does some great work!!!! He might be able to salvage yours or get you another pair.
Old Aug 22, 2005 | 05:00 PM
redwing76's Avatar
redwing76
Originally Posted by wgc_3
Ladies, and Gents,
Thanks,
Bill
How do you crack the heads without cracking the block. Do a compression check on your engine. My 75 coupe had a cracked head that in turn cracked the block.
Old Aug 22, 2005 | 06:19 PM
TM-Z06's Avatar
TM-Z06
I agree - Aluminum heads will warp....but crack? Did you overheat badly?
Old Aug 22, 2005 | 06:24 PM
wgc_3's Avatar
wgc_3
Mistake-
Some how I blew the head gasket, don't know how but oil is ALL over the drivers side of the engine.
Old Aug 23, 2005 | 12:08 PM
TM-Z06's Avatar
TM-Z06
Mistake-
Blowing a head gasket is internal.... if this is the case your oil will look like a chocolate milkshake. Oil shouldn't be on the outside of the engine because of it. This oil you're seeing is probably coming from the valve cover. Is it possible you need to replace your valve cover gaskets? Or you may need to replace your PCV valve. But I doubt you blew a head gasket.
To Cracked Heads
