Digital dash problems
Old Aug 22, 2005 | 09:53 AM
03whitecoupe's Avatar
03whitecoupe
Default Digital dash problems
I had to send my digital dash out to get repaired recently (Gene Taber) but when I got it back it still didn't work. So, I repackaged it up and mailed it back, but Gene said the dash was working fine for him and he even put it in his Vette and drove around to try and get it to fail but it performed as it should. Now, when I get this back again and if it still doesn't work what do I look for. I know about the websites with the information on the clusters but I didn't find them particularly helpful. If I have to take this to get repaired can any reputable shop fix it or should I look for a Corvette shop or a shop that specializes in electrical repair? I doubt I'll be able to fix it myself as electrical issues baffle me. Nothing like spending $185 and still having an inoperable instrument cluster.
Old Aug 22, 2005 | 10:10 AM
Don in Vermont's Avatar
Don in Vermont
Default Inop digital instruments
Hi,
Being somewhat at a loss by not knowing what specifically was wrong with the dash when you sent it in and what the repair shop found when they repaired it I would check the ground connections that support the dig instruments. I would also check the condition of the harness connectors that support the instrument pod.
I had a nagging problem with my dig dash and one of the forum folks suggested the grounds as being a possibility and they were right. I cleaned up the grounds and it works great and had done so for over 6 months.
Good luck,
Don in VT
Old Aug 22, 2005 | 10:25 AM
Saisling's Avatar
Saisling
St. Jude Donor '05
I would check the ground. If you have a bad ground, your cluster could show all kinds of different oddities - as well as not working at all.
Old Aug 22, 2005 | 10:49 AM
03whitecoupe
Which grounds are you referring to and where are they located? Are they easily reached and easy to identify? Thanks.
Old Aug 22, 2005 | 12:44 PM
CMYC4GO's Avatar
CMYC4GO
Gene Taber does excellent work. He's rebuilt two different clusters for me, no problems.
If he said it works for him, then believe me, it's working. The problem is probably in your car.
Old Aug 22, 2005 | 01:02 PM
rick lambert's Avatar
rick lambert
There is a ground wire on the drivers side pillar, just remove the trim and curl the carpet back and you will see it.You can also add a ground wire to the ambient sensor. Check the ground strap on the motor. A great book to buy for about $30 is Gordon Killebrews. It could also be a dirty (coroded) pin connection-on your part, which obviously wouldn't show up at Gene Tabers shop-for that matter neither would the ground problem(s). Since you didn't state what problem you were experiencing-
some problems are do to water in the bulk head connection. You can check this by simply removing the connection and seeing if there is a greenish/whiteish looking substance in the pockets-if there is just blow it out-BUT don't remove the black greasy stuff-it's an anti corosive
lubricant.If you find water there check to make sure the cowl drip tube
is not directed toward it, you can seal the outside top and sides with a spray can of undercoating. Good luck, and get the book.
Old Aug 22, 2005 | 02:29 PM
03whitecoupe
Thanks for the responses. I will get the book and I'm hoping that they have it at Carlisle. My problems with the dash started several weeks back when I decided to go for a Sunday drive and the dash started acting crazy. The segments flashed nonsense readings and became very dim. Finally they just faded out completely and I was stuck with a dead display. That's when I removed it and sent it to Gene Taber. I guess I never considered anything other than a bad display. Stupid on my part. I'll check the ground tonight to see if it's clean and intact. Hopefully that's it. Thanks again.
Old Aug 22, 2005 | 03:45 PM
CMYC4GO's Avatar
CMYC4GO
THAT sounds like a bad Power Supply. Gene would have tested that first, as that is the most common problem. He would have installed a OEM Power Supply, and for a little more $$ he would have installed a super heavy duty one. Whatever you do, don't beat on it. You break the glass lenses, and you're gonna have to 2nd mortgage your house to get the money to repair them.
Old Aug 22, 2005 | 08:36 PM
sadieofeden's Avatar
sadieofeden
I also have the same problem.. I have a 1986, was Ind. Pace Car. I had mine worked on..now I have 1/2 of the dash back...The other 1/2 is still not working.. Please send me any info..that works for you.
Old Aug 22, 2005 | 08:48 PM
mikey whipreck's Avatar
mikey whipreck
To Digital dash problems
