Leaking Radiator Cap
Old Aug 30, 2005 | 10:09 AM
Casper's Avatar
Casper
Default Leaking Radiator Cap
The cap is leaking on my '89. What PSI cap do I need to buy? TIA
Old Aug 30, 2005 | 01:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm not sure but the parts guy at Auto Zone will look it up for your Vette and give you the right part.
Old Aug 30, 2005 | 10:47 PM
mitymek's Avatar
mitymek
many parts like that,gas caps,wiper blades etc,are surprisingly priced at the dealer.
i always check there first (just call)when it comes to the vette.
wiper blades were cheaper than napa the other day.whodathunkit.
oh yea,i did buy a rad cap for my 92 at the dealer last year,didnt price it,just wanted the correct look under the hood and the one they had was identical to the old one.
Old Aug 31, 2005 | 01:08 PM
Aardwolf's Avatar
Aardwolf
My stock cap was 16 PSI, it was in bad shape so I got a new 16 PSI cap with the vent valve to release pressure into the over flow should you need to. It's a handy feature. I've a friend with a '95 T/A and '00 Firehawk, they both have 18 PSI caps. My cooling system works well so I stuck with stock PSI.
Old Sep 1, 2005 | 02:01 AM
skeet's Avatar
skeet
My 85 and 88 both have the HD radiator and the factory cap was rated at 17 PSI. I could not get a 17 psi cap at any aftermarket store so I bought an expensive AC Delco from Chevy.
To Leaking Radiator Cap
