1990 c4 fuel problem
Old Sep 3, 2005 | 05:22 PM
fastf's Avatar
fastf
3rd Gear
Default 1990 c4 fuel problem
we recently had a bad rain storm up in Boston, after the rain the car ran rough, now when I go to start it the fuel pump relay does not sound and it is not getting any fuel. I am questioning the ECM may of gotten wet due to it's location, or is it possible that the fuel pump shut down some how? or that water may have gotten into the tank?
Any help would be great.
Frank
Old Sep 3, 2005 | 05:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What year Vette???
It's not likely that water got into the tank if the cap was on tightly and the drain is not clogged.
Let it dry off and try again.
Old Sep 3, 2005 | 06:29 PM
Midnite 88's Avatar
Midnite 88
Start with the basics. Verify that you are getting fuel. Take the cover off of the schrader valve, with the ignition turned on, use a screwdriver tip or more ideally connect a fuel pressure guage and see that there is fuel at the schrader valve.
If you need more help please don't hesitate to contact me.
Mike.
Old Sep 4, 2005 | 11:18 AM
fastf's Avatar
fastf
3rd Gear
Thank you I will try that. The fuel pump usually makes some sort of sound when I turn on the key, now it is not. Is there a fuse for the pump? Thanks
Frank
Old Sep 4, 2005 | 03:51 PM
Midnite 88's Avatar
Midnite 88
should be in the fuse box marked FP1.
To 1990 c4 fuel problem
