Will any double din radio fit in a C4 or are there only certain ones?
Before I get blasted(some people live for this on this forum), I posted this in the Audio section and did not get a response.
That is my understanding, however I would double check the mea. on a new deck. the only real issue I saw in there is length (which can be adj. by cutting back plastic) width of the deck (room ness. for ears) , and the offset of the mounting ears. Most new ones have an adj. set of "ears" for mounting. I would double check meas. of new one. IBTM
I thought it was 1.5 din. However, since you have a limited selection with either of those id look for a regular 1 din and just get an adapter for it. I went with an Alpine.
there is always a chance in wont fit perfect. i have a single din in mine and one of the rca jacks hit the back and had to cut a little bit of the plastic behind it to get it in.
I'm not sure about any DDins but Pioneer makes one that that goes for around $200; it just drops right in and even has low level outputs for interface with the Bose amps & speakers if you so desire.
