LSx into a C4???
--What is the feasibility of dropping an LS6/7 into a C4?
Reason I ask is I'm intrigued by the fact that GMPP will or is making the LS7 available as a crate motor, and the cost of comparable HP from even a 383 is getting "up there". (Hmmmm..... A daily driver making over 500 ponies, NA; no muss no fuss...??)
Has anyone done the LSx to C4 swap, and what would entail to get a computer for the LS(7), for the sake of discussion? I understand there are SEVERAL individual computers aboard the C6. What all would be entailed to get the LS7 under the '95 hood?
And a related question: I get frustrated
trying to find a part or even a catalog at GM Parts Direct. (I saw once that they were offering a crate LS2 for $5000!) If I don't have the part number, the only option is that catalog web page and that isn't all that easy to use either
.P.
This question is getting beat up more than the "airfoil" threads of old... I may have to start one of those again
To address the original question, it is very possible, but it will take an immense amount of $$$ investment and far too much time to make it worth while... no I have not done it, but that is the general consensus here.
It is doable and depending on how far you go will determine how much.
There are plenty of guys out there putting LT1 and LS1s into older hot rods and keeping the fuel injection.
You can buy a complete LS1 and trans off ebay for less than $5k and that includes everything you need.
I did the LT1 swap into my 84 and if I where to do it today to my 94 it would be the LS1.
The best way would to get a F-body A-4 set up and then the rest would be a lot simpler.
motor mount adapter plates (S&P sells them for $80)
electrical, do it your self or get someone to fab a 4 wire hook up for an LSx harness (Jims performance can do this)
Exhaust, Trial and error here or fab your own
Assy's, This one would need to be test fitted to see if the LS1 assy will fit as is or if some fab work would have to be done.
ECM, send it off and get VATS disabled and any codes you need disabled such as emisions that may need to be eliminated (rear O2s come to mind)
Ther is a guy in NC sticking LT1 and LS1 motors in everything you can think of, his most popular conversion is sticking an LT1 into a Jag, he had three on his lot the last time I was up there.
As far as monetary investment, eh. Half dozen of one... If you are asking if its possible, I probably wouldnt do it if money was a factor. Watch enough Monster Garage, American Hot Rod, and hell if your bored enough, that show on MTV where they make POS's into... into... uh, better than POS's. Just about anything can be done.
Here is another option: http://www.dartheads.com/sbcironeagle.aspx Large cube small block, good for up to 455CID. Make those new Z06 owners green with envy with 28 more cubes.
Why not just beef up your present engine?
I couldn't imagine the fitment issues, and especially the electrical/ECM issues involved.
My question is though, why doesn't GM have any LTx crates available???
http://fuzzydiceracing.com/k/Bako_Run_4-15.mpg
Just a point of refernce. Three years ago I asked about how ahrd it would be to swap a LT1 into a crossfire car because I had a great deal on a LT1 with harness,ECM and assy's and everyone told me it would be a lot cheaper to build my current motor. I was able to compleate the LT1 swap for $3500 and that included rebuilding the LT1 with ported heads. Many don't realy get into Fab work but I think a LS1 project could be done for about 1.5-2K plus Motor, Trans and ECM and Harness. Now that does not include rebuilding the motor so you would need to start with a good motor.
$1000 LT1
$800 (Head work)
$900 (Rebuild kit for LT1, including H/C, the block did not need to be bored so I reused stock pistons and crank)
$300 (Block work)
$500 (Misc items)
I'm a ways off from beginning my upgrade project - still doing the research (wishing to take advantages of the rich experience on this board which is incredible!). I'll probably tear her down next winter, so I have a year to learn as much as I can about what it takes to do exactly what I want it to do. (It's sort of like buying a manual-only 35mm camera...It forces you to learn and to think about every aspect photograph.)
I don't intend to experiment for experimenting sake, but I do want to understand these things to the point I can really be dangerous!
No really, I just want to get to the point where I can spec my mod project and have a reasonable idea of what the end result is going to be. Lots of roads to take - NA, FI, flow rates, cam grinds, etc... I just need to understand what the advantages and disadvantages are of each one, and Uz guyz are really putting me on the learning fast track!
Thanks again for indulging me.
P.
. I'm still in the research mode and I appreciate the input - all of it.Thanks again y'all!
P.
