hi! sometime back someone posted about a build sheet being stuck in the frame rail -from the factory-on his vette.said there is a small round hole close to the front. i have a 1990 coupe and have looked for this hole,but can't find it.can someone shed some light on this? i would also like to know how to power my aftermarket radio up after replacing the battery.thanks a lot!!---jp
I've heard of them being under/ att. to bottom of front seat cushion
Radio should have power after install batt. con.....push POWER on radio? No I'm not being a wise guy, but you might have an issue of how you wired it in the system , a test light w/batt. hooked test leads at connections would be the first thing I would be looking at, certainly would need more details. Then the mods will probably move this to audio sec.
