Done with Dynomat install
Old Sep 26, 2005 | 01:37 PM
WayneGro's Avatar
WayneGro
Default Done with Dynomat install
Thanks to your help I finished my install of Dynomat in my 96 CE Corvette. I can tell you it was well worth the time, more then expected (6+ hours), the money (around 2 bills), and the cuts in my hand (nobody told me this stuff was that brutal). The sound system sounds better, all miscellaneous resonance and squeaks have diminished considerably and the road noise is considerably quieter.
I'm a big fan of my cars rumble however; I'm a big fan of it being outside the car not inside.
This is a must for all cars in my opinion. Thanks everyone who talked me into doing this.
Old Sep 26, 2005 | 01:42 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Did you take any pics of the install?
Old Sep 26, 2005 | 02:01 PM
WayneGro's Avatar
WayneGro
Default PIcs
I'll upload them later tonight. I only took a couple.
Old Sep 26, 2005 | 02:11 PM
Hogan's Avatar
Hogan
Cool, I'm thinking about putting some Dynomat around the back under the hatch and maybe some around the trans tunnel to cut down on the heat.
Old Sep 26, 2005 | 02:23 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Is there any way that you can visually tell it was installed? Did you have to replace any parts because of the install?
Old Sep 26, 2005 | 04:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Do you know how much it weighs/sq ft??
While I was under the rear installing the sway bar bushings I noticed how the two rear carbo "boxes" just hang down on either sidr of the exhaust system, sort of like "acoustic chambers"???
I'm wondering if using such a matt in the rear area and down the back behind the seats would be the ticket to reduce external sound feedback.
Old Sep 26, 2005 | 06:01 PM
Red Tornado's Avatar
Red Tornado
sounds intriguing.....i'm ALL for bettering the sound of the Blose, as well as quieting the blast that exits out the rear every second
Old Sep 26, 2005 | 07:21 PM
okies93's Avatar
okies93
St. Jude Donor 06
cool, that is on top of my long to do list. how much change did you find under the seat? pics of the job would be a plus.
Old Sep 27, 2005 | 07:48 AM
WayneGro's Avatar
WayneGro
No... there is absolutely no trace of it unless you pull the carpet out.
Old Sep 27, 2005 | 07:51 AM
WayneGro's Avatar
WayneGro
Absolutely, you would be amazed at the heat reduction from the motor/road, and the acoustical properties it gives over stock insulation. I left the insulation in as well, just installed the Dynomat underneath everything.
The biggest pain was the Bose speaker inlets. Lots of wierd angles but it's easy to patch with different pieces and it's not visiable at all.
Old Sep 27, 2005 | 07:55 AM
WayneGro's Avatar
WayneGro
12" x 36" Dynamat Xtreme. Coverage: 3.00 ft2 (0.28m2) Weight: 1.35, and 10" x 10" Dynamat Original. Coverage: 0.69 ft2 (0.06m2). Weight: 0.47 pounds.
I used Xtreme. I'm not sure if it's easier to install or not. Before this project I had zero knowledge of this stuff.
Old Sep 27, 2005 | 10:36 AM
65Z01's Avatar
65Z01
Thanks for the info, that's like no weight added at all.
Old Sep 27, 2005 | 12:15 PM
Aardwolf's Avatar
Aardwolf
I thought that was funny to when I saw those! The drivers side has matting packed around the ABS. I've planned to stuff the same in the passenger side.
Old Sep 27, 2005 | 03:26 PM
avideo's Avatar
avideo
Default Thanks For Mentioning Dynomat...
I installed some in my older 1987 Coupe and it cut way down on noise from the dash area and the doors. As I still have a 18-20 square feet of material left, I will make a point to install it in the rear compartment of my 1995 Coupe this winter when I replace the rear carpet. Will likely do the rest when I replace the front at some future time.
To Done with Dynomat install
By Michael S. Palmer | 2026-06-03 09:39:05
