What is the black rectangular device behind the carpet in the rear compartment against the back wall?? It appears to be some kind of antenna. Its in a 94 Coupe, and if you look closely you can JUST see it in this pic.....Thanks in advance
I can't exactly tell in this pic' what you are refering too, but if it has the antenna co ax going to it then it is cm. If memory serves it was relocated from under the pass. dash to there in 92
Its a 94, and its on the back wall off the rear compartment, not the ABS/ASR unit, thats behind the passenger seat. It is very hard to see in the pic there yes. It has no coax cable, just a 2 pin connector. It has fine red colour wire wrapped around it like an AM loop antenna of some kind. I just dont know what its for. What is "cm" that you refer to?
CM, I refered to would be the Radio Reciever Box on mine located under Kick panel (90) when I was in there and considered original Bose replacement Dr. Don told me about relocation like the later model (92-96). If it was that, it should have the antenna coax. going to it as well as other leads. I'm not sure what it is you have, maybe an aftermarket antenna signal booster?
Just saw your revised pic. I think C4 cruiser is right, pretty sure those would be the only 2 options at that point
thanks for that guys, id say you might be right, i didnt know the PKE antenna would be in there,but i spose there is as good a place as any eh. If its an AM signal booster, it certainly doesnt work!!
