Dim Headlight
Old Oct 11, 2005 | 02:16 AM
zoro's Avatar
zoro
Default Dim Headlight
I thought I had a burned out headlight so took the opportunity to put in some Bosch replacements so I could change bulbs if I wanted. After the change that side is still very dim.
Any ideas on what to check now?
Old Oct 11, 2005 | 07:53 AM
1quik91's Avatar
1quik91
Check your wire leads, may be a break or worn line or faulty connection.
Old Oct 11, 2005 | 08:05 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Lots of times dim lights can be traced to bad grounds. Go over your wires carefully.
Old Oct 11, 2005 | 09:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/Headl...0Foglights.pdf
Old Oct 11, 2005 | 10:23 AM
zoro's Avatar
zoro
thanks for the replies
I will be checking the wires carefully
Old Oct 12, 2005 | 12:00 AM
zoro's Avatar
zoro
it was a broken ground wire near the headlight pivot
To Dim Headlight
