G92 RPO code
Old Oct 30, 2005 | 12:24 AM
Ericsvette's Avatar
Ericsvette
Default G92 RPO code
I have a '93 and they had an option called Performance Axle Ratio, RPO code G92, it only cost $50.00. My car doesn't have this but I was just curious as to what it was.
Old Oct 30, 2005 | 12:52 AM
vader86's Avatar
vader86
It was...
the most useless code GM ever introduced. It means the orderer wanted the best axle ratio available for the cars other options (tranny, vert/coupe), thats all it means.
Old Oct 30, 2005 | 12:59 AM
Ericsvette's Avatar
Ericsvette
Old Oct 30, 2005 | 01:02 AM
imaruby's Avatar
imaruby
If you have a automatic transmisson it meant you got a 3.07 rear axle ratio as opposed to the standard 2.93.It will be quicker from the start but sacrifices some gas milage.
Ray
Old Oct 30, 2005 | 01:15 AM
Ericsvette's Avatar
Ericsvette
I have the 6 speed with 3.45's.
Old Oct 30, 2005 | 10:46 AM
vader86's Avatar
vader86
Ray
In a coupe, not necessarily a vert.
Old Oct 30, 2005 | 11:19 AM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
On a 93 auto. it would be a 3.07 instead of the standard 2.59
Old Oct 30, 2005 | 11:37 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default not avail. on yours...
G92 was not an option on the 6 speeds for your year - the 3.45 was the gear avail. w. the 6 spd
As stated earlier, it was in general, a Performance Axle ratio (3.07) for the automatics generally equipped w/ 2.59's or 2.7x gears
Old Oct 30, 2005 | 12:17 PM
c4cruiser's Avatar
c4cruiser
The G92 indicates a Performance Axle Ratio, but not necessiarily a specifc value. The automatic coupes got a 3.07 ratio (RPO G44) and the verts got a 2.73 (RPO GU2) as the "Performance Axle". Both the G92 and one of the other RPO codes would be listed on the option sticker if the performance axle was ordered.
The base gear ratio for auto verts was a 2.59 (RPO GM1) and the base for the coupe was the 2.73 (RPO GU2).
To G92 RPO code
