90 roof
Old Nov 12, 2005 | 02:34 PM
rick50's Avatar
rick50
Cruising
Default 90 roof
I recently bought a clear roof for my 90 vette, it comes off a 88 35th aniv. model. the mounts for the front bolts do not line up with the front mounts on my 1990. The brackets on the clear roof are adjustable but not enough to line up. Any solutions ???
Old Nov 12, 2005 | 03:01 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
either get a roof for an 89 and later, or get the correct mounting brackets to match your top brackets. seems that gm made two or three mounting patterns for the tops. i have a late 86 coupe here that is 31 3/8 from centerline to centerline of the bolts. you can measure your centerline distance of the top from the holes.
Old Nov 13, 2005 | 10:53 AM
rick50's Avatar
rick50
Cruising
thanks for the info, I think I might try to elongate the bracket mounting holes with a die grinder if I can't buy different brackets, the difference in space is less than 1 inch on each side.
To 90 roof
