replace convertible Third brake light
Old Nov 20, 2005 | 10:50 AM
Qiken's Avatar
Qiken
Default replace convertible Third brake light
What is the easiest way to access and remove/replace the third brake light in an 89 convertible and keep smiling??
Old Nov 20, 2005 | 11:54 AM
red86nado's Avatar
red86nado
On my 86, I removed gas filler lid and the rubber gasket that surrounds the neck. Get a 10mm open end wrench, squeeze your arm past the gas neck, and feel for the stamped sheet metal nuts on either end of the 3rd brake light housing. Obviously, it's a tight space...once you get the nut loose you can do the rest with your fingers. Support the light from the outside and you'll be able to access the rest of the screws to replace the bulb. Remember to check the brake lights before you put it all back together! Good luck!
Old Nov 20, 2005 | 02:37 PM
Qiken's Avatar
Qiken
Thanks, I'm actually replacing the whole housing due to a badly faded lens
Old Nov 21, 2005 | 04:57 PM
ElCheevo's Avatar
ElCheevo
On my 92 convertible I took off the rear license plate and backup lights. There is a pretty good hole up there all the way to the rear backup light. Also replaced all the bulbs while I had it apart, Backup bulbs and license plate bulb.
Old Nov 21, 2005 | 05:07 PM
SJW's Avatar
SJW
I got mine out on my '94 by removing the license plate, and going at it through the hole it left. I didn't need to remove the backup lights. Can't say for sure that it'd be the same with an '89, but I'd suggest you yank the plate and have a shot at it.
Be well,
SJW
Old Nov 21, 2005 | 06:24 PM
rstackjd's Avatar
rstackjd
Sorry - you have to pick one - they are mutually exclusive choices!
Seriously, I think ElCheevo's method is the way to go. Just replaced some bulbs in my '88 vert (not the center brake light though) and found removing the inside taillight housing was the way to go.
Good luck
Old Nov 21, 2005 | 08:48 PM
Qiken's Avatar
Qiken
Good luck
Always good to have a couple of options, thanks Guys
To replace convertible Third brake light
