stock 89 cam specs
http://forums.corvetteforum.com/showthread.php?t=960576
Also, i'm not sure if the IROC with teh L98 had the same specs but I found this
1989 (LB9 Auto) 1989 (LB9 5 speed, L98)
Duration @ 50: 179/194 Duration @ 50: 207/213
Lift (1.5): 350/384 Lift (1.5): 415/430
LSA: 109.0 LSA: 117.0
GM Part #10088155 GM Part #10066049
Received 1,405 Likes
My website has them all
Waka, Waka, Waka!
1 Post
CI 4-6-8 & 10 Veteran
St. Jude Contributor
BTW : Thanks again for putting up all the info.
Waka, Waka, Waka!
1 Post
Originally Posted by MBDiagMan
vader86,
So how can I find your website?
Thanks,
Thanks,
Originally Posted by Fozzy_Bear
Not that I doubt your info, but just to confirm: Were the cams the same on the Iron and Alum' heads in '86?
