Need help with Cooling Problem
Symptoms
1. Temperature rises until I turn the car off.
2. Small fan in front of condenser will kick on at 225 degrees.
3. Temperature continues to rise.
4. I installed a switch for the fan behind the radiator.
5. Now, with both fans on, temperature still continues to rise. When
the temp gets to around 240, I'll turn the car off as not to cause
any damage.
Before this started, the car would reach 225, the fan would turn
on, and the temp would immediately drop to about 208, then the
fan would cut off.
Repair Attempts
1. Removed radiator. Had it disassembled, reamed out/cleaned
and reinstalled.
2. Installed new water pump.
3. Installed new thermostat.
Any Suggestions?
Fill the over flow tank daily. Start the car and check to see if the coolant is flowing into the over flow tank.
Feel the upper and lower hoses at operating temps they should be close to the same temps. If one is hot and the other cold it could be the thermostat.
What thermostat is it, is it upside down?
Head gasket? Are you seeing white smoke at startup and maybe some surge at idle?
The only white smoke I get is on the first startup in the morning. After that, no more smoke.
Coolant levels in the radiator and reservior look constant. No drop in levels and no coolant spot in my driveway.
Also installed new radiator cap and cleaned cooling fins on condenser and radiator.
What about the coolant to water ratio? Proper?
It seems that you have replaced/fixed the obvious potential culprits.
Main Fan Relay is grounded by the ECM when the Engine Coolant Temp Sensor - on the Intake, below the Throttle Body - indicates 226 degrees (a/c off); or when the a/c fan switch indicates a high side pressure of 230 psi (a/c on). To verify either, best to use a scanner.
Aux Fan is controlled by a switch in the left head. It grounds the Relay at 228 degrees.
Since your Aux Fan is coming on at an indicated 225 degrees, that switch as well as your Display seem to be working ok. For the Main Fan not to come on, suspect a Faulty Coolant Temp Sensor or it's wiring or ECM or the Relay itself. I'd look into to getting a scanner.
For the engine to overheat with both fans running (and from the factory - it only needed the 1 fan to stay under 226 degrees), the radiator full, the thermostat open, and no obstructions, I'd suspect the water pump, though I see you've replaced it. That leaves the head gasket - check #7 for coolant - rust on the plug threads or an electrode that looks different than all the rest. If it's leaking exhaust into the coolant, some radiator shops can pick that up with a simple test - though unless you have some of the old coolant, that may be difficult to do - depends on how well you flushed the block.
To solve the gage issue, verify the accuracy of the display (and it's wiring ) by disconnecting the sender on the right head - between #6 & #8. Gage should read LO. Ground the lead to the block - Gage should read 300. If you don't get either, there may be high resistance in the wiring - ohm it out between the sender and the Display Pin D4. If the wiring is ok, the Display probably isn't accurate. If you get the proper reads disconnected and grounded, you can try a new sender. First, though, you might want to see if the Engine Coolant Temp Sender is accurate. The ECM grounds the main fan relay as previously posted - 226 indicated by the ECT. Absent a scanner, spend 9 Bucks on a new sensor and compare how many ohms it reads across it's terminals with the one installed in your Vette after the engine has sat overnight. If close, the one in your Vette is probably ok. That leaves the wiring. Signal is yellow from Pin C10 at the ECM. Disconnect it at both ends and see if there's any resistance in it. With it plugged in at the ECM but disconnected at the sensor, verify that it has 5 volts at the ECM and at the connector (which is another way of verifying that there isn't high resistance in the circuit). If it doesn't have the 5 volts at the ECM, you probably need a new ECM.
i had a friend who would flush the radiator on his 5.0L mustang in the following way. he would drain the radiator by opening the lower stop-**** and then close it. the radiator would be filled with tap water from the garden hose. he'd then turn the car on and then reopen the lower stop **** while keeping the garden hose stuck in the radiator until everything came out clean for a minute or so.
it always seemed like a bad idea to me. i just didn't think the idea of running cold water constantly through the motor was all that great. i could never find anything anywhere that stated otherwise though. any thoughts?
I switched this back and forth about 10 times until it came out clear instantly both ways. Those magic in a bottle fixes can't get all the crud out, but it helps to put one in there and run the car and let it do its thing to help break down the corrosion before powerflushing. Also if you dont have your hose connection secured on there good, it will blow off and spray everywhere. The cooling system is very restrictive.
Big *****
