Horsepower Comparisons
In 71 the engines were toned down, I believe the insurance industry caused that... Then again in 74 (if memory serves correctly) when very crude emissions started taking hold...
GM has ALWAYS rated its cars in terms of crank HP. It has never spec'd a car at RWHP.
It just changed the way it rated them at the crank in 72. One is as if it was just a race motor with headers, WP, and alternator....one is as if it was actually in the car with everything that goes into production.
A chassis dynamometer is used to measure power output with the engine installed in a vehicle. It will produce measurements expressed in Rear Wheel HorsePower (RWHP) for a rear-wheel drive vehicle.
A chassis dyno cannot directly or accurately measure flywheel HP. A reasonable approximation of flywheel HP may be calculated based upon the RWHP, using derating values to subtract friction losses in the drivetrain (approximations sometimes used are 15% driveline loss for a manual transmission, and 18% for an automatic transmission).
The SAE (Society of Automotive Engineers) mandated that all manufacturer's engine output ratings would be expressed in Net HP (at the flywheel, of course), as opposed to the previously-used Gross HP, beginning in 1972. This was done to eliminate much of the chicanery that had been previously used by manufacturers to artificially inflate the power output for bragging rights during the horsepower wars of the '60s and '70s. SAE Net HP is a far more accurate measurement than was Gross HP of an engine's actual, useable power output.
The LT-1 of 1970, which was rated at 370 peak HP, actually produced an output very comparable to the '92 - '96 LT1 (one of the reasons for the decision to re-use the LT1 designation, albeit with the hyphen removed). In the current issue of Corvette Enthusiast magazine is an article by Hib Halverson, featuring a C3 LT-1 car. In that article, Hib notes that the LT-1 of 1970 would have generated a SAE Net HP rating somewhere in the range of 290 to 310, which is somewhere in the range of 80% of the 370 Gross HP rating claimed for this engine in 1970.
The 1971 LT-1 was rated at 330 peak HP (expressed in Gross HP, as was the case in 1970). The 40 HP reduction was a result of a lowered compression ratio (a change dictated by GM management in preparation for the impending elimination of high-octane leaded fuel). If I recall correctly, the LT-1 compression ratio was 11:1 in 1970 and 9:1 in 1971.
The LT-1 was rated at 255 SAE Net HP in 1972. Compared to the 370 HP rating of the 1970 LT-1, this reflects a relatively small actual ouput reduction as a result of the reduced compression ratio, with the remainder of the apparent reduction being a result of the change to expressing output in SAE Net HP, rather than Gross HP as was previously permitted.
A stock C4 LT1 car would probably turn 1/4 mile ETs that are slightly better than could be turned by a stock 1970 LT-1 car, with traction accounting for much of the advantage to the C4 LT1.
Does this help?
Be well,
SJW
As I understand it, the LT1 designation was selected for use with the new 300 HP (SAE Net) second-generation SBC because its output and performance were very comparable to the old high-compression, solid-lifter LT-1 engine that debuted in 1970.
Be well,
SJW
Be well,
SJW
The motor is not in the car to measure net, its on an engine dyno but with the production tune, exhaust, and all accessories that could put a drag on it.
Exactly
Others, please stop
...and now we have (voluntary) SAE ratings
465 lb-ft trqe - 575 lb-ft trqe
1987-1991
Nope.
The old method allowed the engine to be run on the dyno and rated without alternator, without air filter, without mufflers, without power steering pump, without AC compressor.
The new method required that all accessories and exhaust be functioning, just like on the actual car.
At one time, GM said that the LT4 was "the most powerful small-block ever made for production." If this is true, then it would have had to out pull the 375hp small blocks of the sixties/early seventies.
The question now is this: was that statement true?? Who knows.
Larry
code5coupe
Net HP ratings are based upon an SAE standard, and are based upon engine dyno measurements taken using an engine that has all emissions control equipment, air cleaner, etc installed. These are engine dyno measurements, so this is FlyWheel HorsePower, not RWHP. Manufacturers' engine output specs are FWHP, as they speak to the engine's output, not the output to the driven wheels of a vehicle (which would vary depending upon transmission installed -- manual vs automatic -- etc).
Be well,
SJW
