The place i am sure i have seen it stated FACTORY FITTED ENGINES. Not RPO. Which means it doenst count, cause the car never left the factory in BG with the RPO-B2K engine(which i know youll know since youve got a few of them!! ). It was near the start of the 1994 owner's video tape.
You know, that is the same old argument that is used all the time - it was simply logistics... It was a GM RPO and is recocognized as such.
FWIW, think of changing dyno standards as continually improving their accuracy. The SAE recently came out with an even newer net standard that has resulted in the decrease in ratings of some cars (the Camry "lost" 20hp for example under the new ratings standard) and the increase in others (the STS-V was rated at 469hp under the new standard, while GM was expecting about 440hp). I believe the newest SAE standard even requires an independent third-party to be present to witness the test conditions.
The big change from gross to net was to have ratings that more accurately reflected the power the engines made. Otherwise it was pretty hard to compare numbers between cars, as the number depended greatly on what number the manufacturer wanted the car to have. I believe under the gross ratings, cars could run without exhaust systems, without accessories, etc.
As to the LT1, I have heard the same thing, the name was used because it had specific power greater than the original LT1. I don't think it matched the rpm range, though. Wasn't the original LT1 a bit of a revver? Whatever the real reason or rational, it was this redesigned SBC that revived the name, not the ZR-1 or B2K. And the B2K motor already had a name, one introduced in 1985. The L98.
All of this is correct, except that it was an engine, not a "car" that was run on the dyno (remember, these are engine dyno numbers, consequently the engine was not in a car, but rather was run on a stand). The Gross HP engine dyno runs were typically run with no air cleaner, open exhaust, no emissions equipment, no accessories. As well, the test engines often did not have the same tuning (A/F ratios, advance curves, etc) as the production engines, if what I've read is true...
The first-generation LT-1 was indeed built to spin. It was a solid-lifter engine (the last of the solid-lifter Corvettes). If I recall correctly, its peak HP was measured at 6000 RPM, and they were commonly revved considerably north of that in practice.
Look, I do not know who produced or put together your video however, since it has an RPO code, you point is well, pointless...
NCRS, , Bloomington Gold, Black Book and all other Corvette authorities recognize it as a Production Corvette.
It is the only Corvette to ever be issued an RPO for an engine made this way - and will probably never be done again.
End of discussion.
Im not interested in the B2K, i said i "heard/read" (thats both before you ask) exactly as i stated above (and stated by Aurora40 below)as the reason for the name being LT1, so IF im wrong, why dont you tell us WHY it was called LT1? Cause im interested to hear your theory.
And it looks like i wasnt the only one to hear it either.
GM did, its the one that comes with the car. The point isnt pointless, cause you MISSED it.
Originally Posted by 90Indy
The LT1 from 1970 is a 350 ci 370hp/380tq.
The 92-96 LT1 is rated 300bhp/330ftlbs and 340ftlbs torque. So what i stated, which was.....
Originally Posted by Casethecorvetteman
The 92-96 LT1 is called LT1 cause it is the first engine to go into a Corvette that is more powerful than the old C3 LT-1 or so i am lead to believe....
.....is very relevant in showing the difference between gross and net HP readings.
Thanks,
C4DC, vader86, SJW for answering my question.
Hopefully sometime next year we can get the '94 on the dyno for a baseline reading before doing some mods. We would like to bump it up a little.
Michele
Couple things-the 50th anniversary edition "CORVETTE An American Classic" by Dan Lyons and John F. Kazt can answer a miriad of your questions.And every vette from 1953 through 2003 was rated at Bhp at a certain RPM. Also, lets not forget-the detune factor. MFGs were pressured to get better fuel economy and less emissions-some of the early sbc had 10.5:1 and as high as 12.5:1 compression ratios. Our C4
l98 are mostly 9 to 9.5:1 with acception of 1991 which was 10.0:1
PLEASE notice I'm only refering to l98s-not the the lts.And yes-GM actually down rated some engine HP for insurance purposes.
