explain coolant low sensor
Old Dec 15, 2005 | 09:45 PM
WEH 2000C5's Avatar
WEH 2000C5
Default explain coolant low sensor
I have a low coolant lite on my 91 L 98. I Pulled the sensor out of the bottom of expansion tank. Sensor looks like cheap xmas lite bulb with 2 wires exposed on top. only mention of it in "FSM " is section #8 showing circuit schematic. My electronic skills are vacuum tube era.
Anyone familiar with this small glass tube ,how it works & what its proper name is.? Thank You.
Warren
Old Dec 15, 2005 | 09:52 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Coolant level sensor, I believe is the name. It works off of a voltage signal from the ECM. And the amount of voltage returned informs the computer as to whether the sensor is immersed in coolant or not. Failure of these is not uncommon, especially as a vehicle ages.
Old Dec 15, 2005 | 10:38 PM
jfb's Avatar
jfb
The sensor makes contact with the coolant which causes electrical conductivity. If no conduction occurs, then no coolant is in contact and the low coolant light will be lit by the circuit that is activated by high sensor resistance.
Old Dec 16, 2005 | 07:22 AM
corvette1989bham's Avatar
corvette1989bham
Long story short, if the light only comes on and off for a while, the filler neck where the sensor is located is ABOVE the engine waterline by design. Park your car on a slight hill nose foward. Run the car will cap not tight until motor is warm (not hot) take off cap run engine at 1500 rpm until warm fill radiator with water until the BRIM OF NECK while engine is at 1500 rpms do not let drop below. When coolant is full (basically running over) put the cap on radiator, that will eliminate the two inch air pocket on top of the filler neck and radiator. This will cure an intermittant coolant light problem assuming no leaks exists.
To explain coolant low sensor
