New Flameball
Old Dec 23, 2005 | 11:21 AM
VettBrat's Avatar
VettBrat
Default New Flameball
I bought a Flameball shift **** for my 96. I shift diagram popped off and there was nut under it, but no. I tried to unscrew the ****, but it won't move. Any tricks on getting the old **** off?
Old Dec 23, 2005 | 12:46 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
On my 87 automatic there is a snap ring way down inside that needs to be removed and then the **** pulls straight up and off. Not sure of the later C4s though. Shine a bright light down in there and see if there is a snap ring. Here is the tool to remove it.
Old Dec 23, 2005 | 04:59 PM
Perfusion's Avatar
Perfusion
The metal "plug" that you see under the shift diagram has to come out. Some take more "wiggling" than others. I used vice grips, IIRC, and a hammer.
Old Dec 23, 2005 | 05:52 PM
87vette's Avatar
87vette
I used needle nose pliers and a screwdriver.
To New Flameball
