His is auto.
Normal change time is 30,000 miles. I'd change it now to be safe.
What may cost about $20-30 now may save you from spending $800 on a new tranny in the future.
Since we are on this subject. What is good fluid for a 95' manual trans? I like using synth stuff but I would rather have some opinions. Also, is there a filter to change with a manual and how do you change it and drain fluid etc etc.
The general consensus here on the forum falls into one of two categories - The GM oil (available from GM with part number 1052931) and the Castrol Synthetic Formula TWS 10W60 (available from BMW with part number 0751009420). The BMW stuff is actually motor oil, and you'll have to pick it up at a dealership's parts counter. The guy might give you a funny look, but don't worry, MANY people here use the stuff.
There is no filter to change with the ZF6. There are two plugs, a drain plug and a fill plug. As always, check to make sure you can loosen the fill plug before removing the drain plug! Nothing like draining all the fluid out of your tranny, only to find that you can't get the fill plug out!
Try searching the Tech Tips section for a "how-to" on changing your own fluid...it's not that difficult, you just have to have the right stuff. The other option is having a local shop do it (and you supply the new fluid). Shouldn't take them more than 30minutes, inlcluding raising/lowering the car on the lift.
Matter of fact, there used to be a ZF transmissions US website. But you might also like to look at zfdoc.com. May be excessive, but their conclusion is changing the man trans fluid every 12K miles.
Per Chris Petris in his C4 class this summer: "It is OK to use Mobil 1 10W30 in the 6-speed." I found this in my class notes.
Quick question - Is it Mobil 1 with or without "Energy Conserving" additives. You'd have to look at the seal on the back of the bottle. It may not make a difference but since they do make two types I thought I'd ask. Thanks,
-Chris
"Chris Petris"...that old dog...lol...great guy and he was the only one to touch my vette until he closed his shop a while ago...he writes full time and does project cars for Corvette Fever now...his shop was only 20 minites from me too... ..that man knows C4's...
