door lock question...
Old Dec 31, 2005 | 05:28 PM
95White's Avatar
95White
4th Gear
Default door lock question...
Anyone have any ideas what might be wrong with my 95 passenger side door lock? It opens fine if I hit the DRIVERS side door lock open switch, but won't open anymore from the PKE proximity. Used to work fine... is there a different circuit for the PKE to open the doors? maybe a relay? Thanks for any help you can give!
Old Dec 31, 2005 | 05:34 PM
ruby9246's Avatar
ruby9246
St. Jude Donor '03-'05-'06-'07-'08
The PKE can be programmed to open the drivers door only or both doors. Could you have possibly changed settings to only open drivers door?
To change settings from opening one to both doors , do the following.
Good luck.
Place key In ignition, leave ignition off.
Hold button for more than 2 seconds. System will recycle door locks.
