Pulled Codes, Need Help!
Old Jan 9, 2006 | 12:27 PM
C6-Stingray's Avatar
C6-Stingray
Default Pulled Codes, Need Help!
Hi every one I just pulled some codes on my '94 Vette & would like to know if its nothing to worry about, and safe to drive and ignore? And the codes are:
H41 Ignition Control Circuit Open
H13 Bank #1 Heated Oxygen Sensor #1 Circuit:
H52 Engine Oil Temperature Sensor Circuit Voltage Low.
H63 Engine Oil Temperature Sensor Circuit Voltage Low.
H15 Engine Coolant Temperature Sensor Circuit Voltage High.
H83 Torque Converter Solenoid Voltage High.
Also how can i delete codes?
Thanx in advance
Old Jan 9, 2006 | 12:34 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I would write them down.Looks like mabey a bad o2 the rest may be the result of unplugging a sensor except for the H83 not sure on that one.An "H" means history.You can clear them by disconnecting the neg bat terminal for 30 sec and try again for fresh codes.The ECT can affect engine operation if the engine is running right I doubt the codes.
