Help on the PKE system
The previous owner still had the key fob in the original package. He said he did not use it. I followed the program in the book and when I press the trip/odo button twice, then the fuel/info button, nothing happens. Also, I noticed when I push the gauge button to get the read out on the dash, nothing happens.
Did not know how it worked untill after I got it home. Any ideas. Other than that, the car is near perfect, only 8,000 miles, new tires and he just replaced the opti since the gasket on the water pump failed Not a good pic
Sorry this was ment for the tech section Last edited by HG; Jan 12, 2006 at 05:29 PM.
Each time you press the guage button, the bottom of the readout should cycle from OIl temp to coolant temp to battery voltage.
The actual readout will show to the left of the gas guage.
Do any of these work??
Try running the oil monitor reset, press ENG/MET twice within 5 seconds and press and hold the GAUGES button. The Change Oil lamp left of the RPM needle should start flashing, about 12 times then goes out. If it doesn't start flashing then perhaps you have a button cluster issue.
... 13 going on 14 and only 8K on the clock probably should expect some of these kinds of issues.
The previous owner still had the key fob in the original package. He said he did not use it. When I purchase my 93, the guy said he pulled the fuse out of the fuse panel for the PKE because he didn't like it.... I'd check the fuse...
If none of that is happening, then this may be an exercise in gaining access to the button cluster. Unplug and then re-plug it in. Ign back to On to see if they work. If not then start your troubleshooting there.
Once the buttons are working then I would first look at enabling the passive mode. If the passive mode is Off or disabled, when you turn the Ign to On the DIC does a bulb test and watch for the PKE lamp to illuminate for just a second then go out. If the PKE lamp on the DIC does not come on as the Ign is first turned to On then the system is not in passive mode.
With the driver's door open and the key removed from the ignition, press and hold the Door button on the transmitter fob. After about 2 secs the locks should cycle. If they do then put the key back in the Ign and do a bulb test again, does the PKE lamp come on for a moment. If it does then you have now enabled passive mode. The system should then be functioning normally.
Check this thread fo rthe aldl pins to short.
Driver's side door lock affecting my non-working PKE
Three Fuses...
RDO Batt. (If the radio works I'd suppose this fuse is good)
PKE Fuse (This one only runs the PKE module and nothing else)
POWER DOOR LOCK Fuse (Runs your power door locks through the PKE module, also provides power to the PKE indicator bulb. If your power door locks work this fuse is probably OK also.)
Sounds like the original poster has problems with the buttons not activating anything in the cluster.
I had a large post about the PKE system and great detail how to troubleshoot it but it must yhave went by the wayside during the server upgrade.
One other thing to look at is the key in ignition switch, you must hear the buzzer (chime) when the key is in and open your door. The key in the ignition switch was bad on my car therefore the PKE system never went into a "ready" state to allow programing. After I fixed that and reslodered every connection in my FOB it worked.
Also codes will not display if the "key in ingnition switch" isn't working.
The schems. below are for a 96 but I suppose a 93 is the same. I'm not sure it's legal to post schems. frankly I don't care. If it's against forum rules please delete them.
Since we're sharing info I thought I'd post pics of what the subject of discussion looks like.
This thing sits right under the dash where heat and dry air can get to it. Not good for solder, even if you can't see any broken connections that doesn't mean there aren't any (been there done that) resolder them anyway. It's kind of a pain because the board is coated and you have to scratch the crap off before you can resolder them.
I relsoldered mine because some looked "iffy" and it's even possible this may have fixed mine. I think it was mostly the key in ignition switch though.
