Opti hoses
Old Jan 14, 2006 | 09:11 PM
95BlueBomber's Avatar
95BlueBomber
Default Opti hoses
I have a question, where do the two vaccuum hoses from the opti go?
Thanks,
The Bomber
Old Jan 14, 2006 | 10:51 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Thought the 'vented' Opti was OE on the 95, so your vacume line engine compartment's diagram may show you where.
Otherwise if your doing a conversion from non-vented to vented, Here is the link the tech-tip which described the conversion, towards the bottom it describes where the vacume lines go:
https://www.corvetteforum.com/techti...=174&TopicID=2
Old Jan 14, 2006 | 11:19 PM
95BlueBomber
My opti is vented. There are two hoses and one is going to the front of the intake, but I don't know where the other one goes?
The Bomber
Old Jan 14, 2006 | 11:29 PM
theadmiral94
The tech tip should help clarify it (without reading it I'd guess the other line would go to a vacume source under the driver side valley cover to some 'T' connector.
Old Jan 15, 2006 | 12:06 PM
scranage's Avatar
scranage
One is vacuum, off the intake. The other is a fresh air source. Take it from somewhere after the air filter. Punch a small hole in the duct in front of the throttle body, and install a grommet, then push the end of the line in there.
The Bomber
Old Jan 16, 2006 | 11:37 AM
Red Dwarf's Avatar
Red Dwarf
Thanks,
The Bomber
I have an illustration from the 95 Helm's. If you would like it e-mail me at lsylvestri@sbcglobal.net.
Old Jan 17, 2006 | 10:12 AM
95BlueBomber
I think I got it figured out... The one with the filters goes to the front of the intake under the throttle body, and the other goes to the air intake duct. Does this sound right?
The Bomber
Old Jan 17, 2006 | 12:17 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
http://corvettefever.com/howto/16758/
The one with the 90 degree fitting goes to the air intake duct.
The other one gets plumbed into intake vacuum.
The article shows how to add a T-fitting to the older cars to get an extra port. But since you have a 95, your just reinstalling it.
Old Jan 22, 2006 | 07:59 PM
Mo_Bandy's Avatar
Mo_Bandy
The hose with the little diaphams plugs into the vacuum nipple above the PCV valve, on the drivers side the other without the diaphrams plus into the air inlet anywhere in front of the throttle body...
hope this helps...
Mo
To Opti hoses
