93 40th Anniversary Ruby / Ruby leather Help
Old Jan 18, 2006 | 08:46 AM
jealkon's Avatar
jealkon
Default 93 40th Anniversary Ruby / Ruby leather Help
Hey guys - need some help figuring offer for this
1993 40th Anniversary Ruby / Ruby leather interior, automatic, newer tires, current inspection, dual power sport seats, removable glass top, selective ride control, electronic climate control, Bose gold C/D, passive keyless entry, 52,400
Car seems tight but what should I specifically look for? Any ideas on price would be appreciated.
Old Jan 18, 2006 | 09:14 AM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
A/C still have a charge? Std. Opti question. Any maintenance records? Look underneath the motor... Any signs of drips? If so most likely the intake leaking. Selective ride control, neat system 13 years are the shocks original?
Whats the asking price? I paid $14K and mine had 33K on it back in 02.
Old Jan 18, 2006 | 09:53 AM
jealkon's Avatar
jealkon
Looking for $15.5 with 54k - everything original
Old Jan 18, 2006 | 10:25 AM
Hogan's Avatar
Hogan
I got a good deal on mine (wz my fathers).... At the time, the dealer was offering $12K as a trade in. Book was showing $15-16 at that time.
Latest Corvette Magazine shows a 40th (Ruby) to be around 13-16 (if memory serves me correctly, I'm at work). I think this is a little high considering C4's have been dropping in value lately.
I'm thinking no more the $13K for the one your looking at. A few members here might find that to be generous.
If you want, when I go home I'll look up the mag and let you know the $$$ they were quoting.
Old Jan 18, 2006 | 10:29 AM
Vetracr's Avatar
Vetracr
Default Ruby value
Bought my pretty mint 63K mile Ruby 6 spd with both tops in 6/05 for $11K. Had some minor mechanical issues when I bought it requiring attention, high idle (vacuum leak, misadjusted minimum air). Also had oil leaks that I'm still working on. Water pump drive seal, opti drive seal and front crank seals leak. Just a note, EVERY LT-1 I checked before buying leaked somewhere. Check all interior switches and accessories such as bolster switch, lumbar switches, pump and bladder, window switches. Many of these are no longer available. Good luck.
Larry
Old Jan 18, 2006 | 11:15 AM
Ericsvette's Avatar
Ericsvette
I bought my Ruby six speed last August for $14,000. He was asking $15,000. It had 36,000 miles on the clock and has every option except the plexi top. The only things wrong with it were both seat bladders didn't work, and the CD player didn't work. Both are common problems. It also needed a brake booster and a right front hub but that's about it. It sounds like a pretty good deal, try knocking the price down another grand. Good luck.
To 93 40th Anniversary Ruby / Ruby leather Help
