Engine off center???
Old Jan 25, 2006 | 06:28 PM
lil'tricia's Avatar
lil'tricia
Cruising
Default Engine off center???
I noticed today that the TPI has a small "bump out" at the back of the engine bay, on the firewall...kind of like a cradle where the back of your TPI should be.
Problem is, by TPI is listing over about 1 inch to the passengers side. The top of my tpi is very close to the firewall.
My dad thinks the passengers side engine mount might be to be to blame. He seems to think the rotation of the engine, over time, would compress the mount down...does that make sense?
It's a 1990 C4 targa auto with only 110k miles on it.
Any ideas???
Old Jan 25, 2006 | 07:03 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
How are you determining that is leaning over?If it really is then the motor mounts would be the first things to check.
Old Jan 25, 2006 | 07:20 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Your dad is right, check out the motor mounts.
Old Jan 25, 2006 | 07:41 PM
Midnite 88's Avatar
Midnite 88
Dads are always right. And when we aren't, we're still not WRONG! Wives are the same way. The only difference is when they are wrong, they are still right. Right? Right!
My wife doesn't read the forum.
Old Jan 25, 2006 | 07:47 PM
Huber84's Avatar
Huber84
Lol...for your sake, I hope not!!
Old Jan 25, 2006 | 07:58 PM
aminnich's Avatar
aminnich
That much lean would more likely mean motor mount broken, which means needs fixed rather soon. Yup, Dad's right again
Old Jan 25, 2006 | 09:33 PM
lil'tricia's Avatar
lil'tricia
Cruising
Thanks Guys!
Do you all think that mount is something he could do? He has a hoist, and he loves working on cars...but he's kind of old, and has a hard time bending his knees.
Has anyone ever done the passengers side mount before, and might you have some advice I can pass along?
And one more silly question. Should I only buy the mount from the dealership, or would any autoparts store be okay?
I'll take a picture of how far off it is tomorrow and post it.
Thanks again!
Old Jan 25, 2006 | 10:02 PM
VQT88Vette's Avatar
VQT88Vette
There are no after market engine mount for C4, have to buy from the dealer. Shop for price, check with chris at superiorchevy.com (Jeff Kopp is the supervisor and belong to this forum). You can replace the mount with a jack. Jack it up at the oil pan. When I did this the ex. manifold weren't in yet... Don't know how tight it is with the ex. man on
Old Jan 25, 2006 | 10:18 PM
aminnich's Avatar
aminnich
Here is name/number of auto shop in Norcross that has been recommended to me. I am too far north of Norcross (closer to Canton) so haven't used them myself so can not personally say anything about their work--just that others have told me they are good and very 'vette knowledgeable. Norcross Auto--phone
770-448-0393. Depends of course which area of Atlanta you are from. There are also several Atlanta area Corvette Clubs that would be good sources for you. Also, Chevy Dealer in Keenesaw area very involved with vette's, but can't remember name right now. Email me if I can help.
Old Jan 26, 2006 | 09:33 AM
aminnich's Avatar
aminnich
Originally Posted by lil'tricia
Thanks Guys!
Thanks again!
If it is m/mount they are cheap--do both sides, if one is gone other side soon will be.
Old Jan 26, 2006 | 10:43 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The motor is located closer to the passenger side. I don't know why GM did that.
Old Jan 26, 2006 | 10:53 AM
HeeHaw89's Avatar
HeeHaw89
From looking at your pic, it looks centered to me.
Nice and clean...how did you get the plenum, runners and covers to look like that?
Old Jan 26, 2006 | 10:57 AM
CentralCoaster
Look at the distance from the smog pipes to the fenderliners.
Also, look closely at your air box, it's not centered either. Either the neck is offset or the whole box is, i don't remember exactly
Old Jan 26, 2006 | 11:53 AM
rightofway's Avatar
rightofway
i have heard that about an inch to the right is normal
Old Jan 26, 2006 | 11:56 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I've had a broken motor mount on a car other than a vette. Anytime I would give the car gas, the motor would torque to one side. The fan woud come up, contact the fan shroud and make a heck of a noise. I think that if you had a broken motor mount you would know it.
CentralCoaster
I just checked, take a look at the air box and you'll see how far over it is.
Old Jan 26, 2006 | 12:15 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Maybe not, but it's something YOU could do, with his guidance and knowledge and "standing-by".
You be the muscle, he be the brain..... That's how the Dad/kid relationship works at this point.
Sure you do, Kevin. It's so the car will be balanced with only the driver in the car...when max performance is required. AT least that's what we tell Porsche owners....
Larry
code5coupe
(old Dad myself)
Old Jan 26, 2006 | 12:17 PM
aminnich's Avatar
aminnich
Don't know about yours, but mine has electric fan, not even close to the motor. You are still sorta right thou, there should be some symptoms other than just a visual look/see, especially when under torque. But I am no expert, not even close, just trying to help.
To Engine off center???
