engine missing
Old Feb 15, 2006 | 01:22 PM
jvette87's Avatar
jvette87
Default engine missing
i just replaced the plugs, wires, dist cap and rotor on my 87 coupe. it still has a miss. first time workin on engines myself. any ideas what i need to check next? the car is a stock L98.
Old Feb 15, 2006 | 04:55 PM
redwing76's Avatar
redwing76
Buy a code reader.
Old Feb 15, 2006 | 06:09 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
check your vacume lines for cracks and breaks, also check for leaky injectors, check plug wires installed correctly and seated on the plugs, add into that that you connected the tac connector and the plugs are seated into the distributor cap.
Old Feb 15, 2006 | 06:10 PM
vinnies87's Avatar
vinnies87
Originally Posted by redwing76
Buy a code reader.
You know, he may not be getting errors just from a miss.
Old Feb 15, 2006 | 06:18 PM
Red Dragon 79's Avatar
Red Dragon 79
i don't know much about the 87 engines, if the distributor is still an adjustable dist like an earlier engine then i would say perhaps a timing light would clear up the situation. maybe it got loose and threw off the timing.
Old Feb 15, 2006 | 07:05 PM
jvette87's Avatar
jvette87
thanks guys
Old Feb 15, 2006 | 08:33 PM
Mo_Bandy's Avatar
Mo_Bandy
Could be a lean miss, how about your fuel filter?
Just a thought...
Mo
Old Feb 15, 2006 | 09:06 PM
Insane1's Avatar
Insane1
I had a plugged injector on my 85 that produced a miss. First need to determine which cylinder is the problem. You can use a squirt bottle to squirt water onto the exhaust to see which hole isn't working and then you can go from there in your troubleshooting.
To engine missing
