Question: How to measure for proper rake?
Old Feb 21, 2006 | 02:22 PM
Gorilla's Avatar
Gorilla
Default Question: How to measure for proper rake?
What is the proper method to measure rake, and how much should there be?
As soon as I can gather enough firewood to heat the shop, I'll be installing my lowering bolts. I'd like to keep from doing myself any ill-fated favors.
The car is stock, not a daily driver, but will hopefully see about 3 days a week on the highway.
Old Feb 21, 2006 | 03:11 PM
tequilaboy's Avatar
tequilaboy
I think the bottom rail/lip below the rocker panels should be parallel to the ground, or level.
Old Feb 21, 2006 | 04:36 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Ride height (rake) is very subjective. Amount of rake is more personal preference ("That looks baaad!") than anything else.
Put it where it looks good to you, get a four-wheel alignment, and enjoy it.
Larry
code5coupe
Old Feb 21, 2006 | 06:42 PM
Steel Blue 91's Avatar
Steel Blue 91
That's how I set mine up. Adjust for your own preference.
Old Feb 23, 2006 | 04:32 PM
astock165's Avatar
astock165
From a handling standpoint you need to have 1/4" to 3/8" for high speed stability. That's how most track used C4s are setup I believe, and how I've set mine up.
To measure: make sure you're on a reasonably flat surface and measure from that surface to the frame/body at the rear arrow of both the front and back jacking locations.
Old Feb 23, 2006 | 04:37 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
After you install the lowering bolts, you will need to take it for a ride to allow the suspension to settle.
I adjusted mine by setting all 4 tires to the same pressure. Then I measured from the ground to the tallest points on the wheels wells and adjusted until all 4 corners were equal.
Old Feb 24, 2006 | 01:35 PM
Gorilla's Avatar
Gorilla
Default Good to Go
Thanks, everyone.
1/4" to 3/8" sounds good to me.
Old Feb 24, 2006 | 01:43 PM
Ironcross's Avatar
Ironcross
Principal reason I like my 84 is that it has no rake. It looks square front and rear. One of the very few C4`s with that type of factory stance. I suspect the reason why however is that it`s one of those rough rider bone jarring Z51 packages that was softened up in 85 and later Vettes.
To Question: How to measure for proper rake?
