Thanks for the pics, The previous owner of my Vette mounted the amp in the back of the cargo area. I will be moving my amp now. Your install
looks really nice.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
looks really nice.
Don't plan on fitting anything much bigger than this amp in there. I even had to use some special rca hookups
Now you can take the rest of the car apart. How does it sound?
I'm gonna go bolt the seat back in and make vrum vrum sounds.
I'm thinking I should mount the video projector in the garage so I can play gran turismo from inside the car, that's about the most action it'll see all month.
Did you think about putting the amp under the pass. seat? Did it take anything away from moving your seat back all the way? I have an amp coming in the mail for my 85, and am looking at my options. Looks good though!
I considered that, this amp is a bit too long and interferes with the manual seat lever up front. It would have involved raising the seat front and back by 3/4" & 1/2". If you get a smaller amp, it'd probably fit fine.
I also considered putting it behind the passenger seat, but there's not as much width there, and it cut off the legroom too much even with me sitting there.
If you're under 5'10" you have about 1-3/4" behind the drivers seat to spare.
