Center console lid broken/codes under it!
Old Mar 16, 2006 | 01:53 PM
5speedC4's Avatar
5speedC4
Default Center console lid broken/codes under it!
What to do? I need to replace the center console lid but the RPO codes would be lost. They are on a sticker under the lid! I feel like they are really important. Advise please...
Old Mar 16, 2006 | 03:19 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Hang the old console on the garage wall.
Old Mar 16, 2006 | 03:43 PM
Red Dwarf's Avatar
Red Dwarf
Try warming the tag with a hairdryer other wise take a photo of it.
Old Mar 16, 2006 | 03:48 PM
behnevette's Avatar
behnevette
I peeled mine off very carefully and stuck it to the new console lid. Your results may vary.
Old Mar 16, 2006 | 03:50 PM
Jet-Jock's Avatar
Jet-Jock
I was able to remove mine with no problem. It just took a long time and a lot of patience. I also did a friends Vette across the street. Very very carefully start to peel it from one corner. Slowly and methodically work the label free. Always pull from the point of attachment not from the part you have worked free. In other words work close to the point of adhesion.
Once off the label retains it's sticky so you can apply it right to the new one. I'd have to pull my old one out of the closet but there was one other label under the console lid that I could not remove. It had a metalic type GM label and it wasn't coming off. The RPO label is different.
Old Mar 16, 2006 | 04:16 PM
87vette's Avatar
87vette
Same here.
Old Mar 16, 2006 | 04:35 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
with the exception of Mojo's advice, I would never try any of the others - no need to!
Get your new lid and change the inner plastic panel over to the new lid - done deal, problem solved. There are about 10 screws to remove & replace in the process...
I hope this helps
Old Mar 16, 2006 | 04:58 PM
jrp's Avatar
jrp
Unless that's the broken part, this was also my first thought.
Old Mar 16, 2006 | 05:01 PM
sonny1974's Avatar
sonny1974
changed mine and checked the rpo codes and i have a 95 polo green. Codes say i have a red lt4 whooo hoo wait a min. wrong lid crap. checked the box behind the seat and my rpo codes are there. o well here come the mods now!
Old Mar 16, 2006 | 06:36 PM
5speedC4's Avatar
5speedC4
I hope this helps
Yep, that the part thats broke.....LOL
But lots of good advise all the same.
Old Mar 17, 2006 | 02:57 PM
obnoxus's Avatar
obnoxus
Thats what I was thinking !!!!!!!
To Center console lid broken/codes under it!
