mechanic help with 86 harmonic balancer
Old Aug 16, 2001 | 10:09 AM
vettmojo's Avatar
vettmojo
Default mechanic help with 86 harmonic balancer
can i get some advise on what it takes to pulll the harmonic balancer and how much would it cost to replace. i have an early 86 vett. the car is runnin hot and stumbles like it has clogged injectors but my mechanic says it is the misalligned harmonic balancer and this is the second opinion. i just want ot know how big of a pain it is to work on. on a 1 to 10 scale. 1 being easy as a tire change and 10 being anything involving transmission work?????
i am having every item on my wish list fixed on my car in the next three months and i will post the receipts online to give others an idea of the cost of maintaining this vehicle, climaxing with a complete paint job
show me the wisdom :confused:
Old Aug 16, 2001 | 11:17 AM
VQT88Vette's Avatar
VQT88Vette
Default Re: mechanic help with 86 harmonic balancer (vettmojo)
In the Tech section "Lars" has an article on how to replace water pump and timing chain. It tells you how to take the harmonic balancer out. If you go that far, change the water pump and timing chain while you're at it
It's going to be a dirty job :yesnod:
I will change my water pump and timing chain very soon, just gather up enough stuff for the task now.
Old Aug 16, 2001 | 01:13 PM
Kale's Avatar
Kale
I had mine idealer installed $150 including parts
Old Aug 16, 2001 | 03:36 PM
Mr. CJ's Avatar
Mr. CJ
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: mechanic help with 86 harmonic balancer (VQT88Vette)
get a harmonic balancer removal tool, it's a piece of cake, let us know if you need help!
To mechanic help with 86 harmonic balancer
