drip drip drip
Old Mar 27, 2006 | 01:35 PM
Red Dragon 79's Avatar
Red Dragon 79
Default drip drip drip
i have a fairly good oil leak coming out of the front of the engine somewhere, i have oil dripping off of the cross bar, i can't see anything up past that bar, would anyone have an idea of where i should even look for the main cause?
Old Mar 27, 2006 | 02:43 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
Well... the best thing to do would be to pressure wash all of teh leaking oil off of your engine... Then put some dye in the crankcase and use an ultraviolet light to find out exactly where it's coming from.
Short of that... your cross bar obviously isn't leaking So see if you can determine where the oil is coming from that is getting on that. It's gotta come from higher up... My guess is porbably valve covers... but the dye is the best way.
Old Mar 27, 2006 | 02:49 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Do not pressure wash your engine unless you enjoy replacing the opti. If you're going to clean off the oil use a product like Simple Green and lots of rags.
Old Mar 27, 2006 | 02:56 PM
ENZVETTE's Avatar
ENZVETTE
I had the same problem and it was my steering rack
Old Mar 27, 2006 | 03:36 PM
Red Dragon 79
what type of dye can i use and where can i get it?
Old Mar 27, 2006 | 03:54 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Those leaks can be deceptive. Check your steering rack, pump and PS lines, too, especially around the fittings.
Old Mar 27, 2006 | 05:17 PM
jrzvette's Avatar
jrzvette
I guess that's the first thing to ask; what kind of oil? Engine oil or PS fluid.
Old Mar 27, 2006 | 06:15 PM
blown87's Avatar
blown87
GA Events Coordinator
Go to a napa store and tell them you want some uv dye for motor oil.
But you have to have a uv light to see it.
Old Mar 27, 2006 | 08:54 PM
Red Dragon 79
thanks everyone
To drip drip drip
