Need Headliner help for a 94
Old Apr 5, 2006 | 10:51 AM
pcolt94's Avatar
pcolt94
Default Need Headliner help for a 94
What I want to know is do you just pull off the old headliner material OR does the actual headliner (the shell) get removed also. If you only take off the material, its not obvious to me at this time how you would get the new material back on and under the existing shell. There is almost no clearance between the headliner shell and the roof pieces that surround it. This is different than other headliners I have done. What is correct procedure?
