88 headlight problem
Old Apr 15, 2006 | 09:56 PM
John88RedVette's Avatar
John88RedVette
Default 88 headlight problem
Hello all, a question here about the headlights on my 88. my right side headlight has resently started sticking about half way through the up and down cycle. It will finally finish the cycle. The left side works fine. Anything I should look for or any suggestions? Thanks < JOHN
Old Apr 15, 2006 | 11:12 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
88 is the first year for the plastic bushing failure motors..It sounds like you have the symtoms of it...It's a cheap deal if you fix it yourself and you can get the parts dirt cheap at Home Depot but I'm not sure what they call them there...Someone will chime in with that info.Otherwise you can pay a lot more for them with Ecklers(still not a big deal)
Old Apr 15, 2006 | 11:33 PM
Justardnck's Avatar
Justardnck
Try this
It lacks pictures but all the info is there. Don't be afraid of this job it's pretty easy
http://domesticmisfits.net/forums/viewtopic.php?t=128
Old Apr 16, 2006 | 01:03 AM
jfb's Avatar
jfb
The headlight wraparound is held on by two screws, one on each side. First check that one of the screws hasn't backed out and stops the door from opening by hitting the hood.
Old Apr 16, 2006 | 10:38 AM
Billy Stargazer's Avatar
Billy Stargazer
I noticed a similar problem just yesterday on my 87. The light was hanging up on part of the frame preventing it from fully righting itself when I turned them on. I messed with it for awhile tightening all of the nust and bolts with no luck. Finally I loosened two of the nuts holding a brace in place just a couple of turns. That solved the problem. Go Figure!
Old Apr 16, 2006 | 09:03 PM
John88RedVette
Default 88 headlights
Oh one more thing I have noticed is that I can still hear the electric motor running for a few seconds even after the headlight is completely up or down....
Old Apr 16, 2006 | 09:08 PM
mfi's Avatar
mfi
Mine does it too. You have to rebuild the guts. You will probably notice a lot of plastic powder near the light. Thats grinded up gear guts.
Old Apr 16, 2006 | 09:19 PM
Daffy's Avatar
Daffy
It's most certainly the bushings...They are now powder....
Old Apr 17, 2006 | 12:29 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Click this link. It'll help you with the install instructions
http://www.corvettefever.com/howto/33098/
The replacement bushing are also available at your local parts store that sells "HELP" / "MOTORMITE" brand items.
They are the same for ford truck window regulators. About $6.00-$8.00 per side at the parts stores.
motormite parts # 74410
To 88 headlight problem
