Radar Detector Mounting Options?
they've never said anything about it.Two suction cups hold it to the top of the windshield and double sticky tape holds it to the header.
It's wired into the non-dimming mirror light for auto on/off with ignition.
I leave it mounted even when parked with the top off and windows up as it really can't be seen from outside.
http://www.zip-products.com/Corvette...5113781F9816AF
that stuff is all a gimmick.. don't ever buy any of it.. radar doesnt reflect off the plate, but rather the entire car...
I have a V1,and it explains in simple to understand detail how everything works in the manual...very good read, even if you don't have a V1 or a radar detector...
I just use the suction mounts in mine since I transfer it between two different cars during the week... REALLY like that screw idea from the rear view...
BTW, the CORRECT placement for OPTIMAL response for any radar detector is as high as possible, but to where it can still see out the front and rear (if you have rear detection)... The higher it is, the better "range" it as, as it can pick things up sooner...being lower to the dash, it can miss things since radar bounces and reflects off objects, such as your hood, etc.
I keep mine just below the rear view mirror in my Tiburon (big back window) but a little more in the middle in the Vette since the roof is a bit lower...
