PreCat elimination question
've got an 90/L98 with an exhaust system that I am planning to replace. It has the two precats on the front Y pipe, then the main center cat. Can I eliminate the front two precats, keep the main center cat and remain "legal"? I no longer have to go through E-Check (Ohio's emission test), but I don't trust that it won't come back. I'm looking to save $$ where I can, pick up power and not cause my hearing to go bad. I've heard some conflicting comments regarding what removing the precats will do to the sound. I'm not looking for louder. I had a local exhaust shop looking into whether or not they could replace the sytem without the precats but I've not heard back yet. I've also read the Ohio EPA regulations, which pretty much states you can't alter the existing system. I can't believe with today's technology that it would matter as long as I keep the main cat.
It will be louder, just not terribly louder. Shouldnt be to the point of causing headaches.
2) Technically, you're not supposed to change the configuration of your emissions. So, technically, you'll be illegal. Practically, no one will care -- including repair shops.
3) Do a search on precats and GREGGPENN. I've done this recently and had some issues with precat removal. You may get popping during warm-up and you may not like it.
4) Ecklers sells a 1 cat replacement that they claim is 49-state legal to replace the 3-cat setup. Call them and ask if this is really true for your state. I'd ask how this works since you're not suppose to change the config of emissions. Their claim is the main cat is a two-stage converter that replaces the combined function of the factory front/rear converters.
5) If you're replacing the front "Y", dropping the front cats, and don't use option #4, consider a 2.5" bolt-up stainless upgrade. (Factory is 2.25"). PM me and I'll point you in the right direction on where this is sold. I bought one!
6) I agree with your last statement. Newer car computers are depending on existence and proper function of the converters. The cars won't easily run without them. My muffler shop thinks this will eliminate the need for inspections. That might be why your state ceased doing them. That's also one reason why no one will care. Also, 84/85 cars didn't have front converters either. So, you really have to know your vettes to spot one without factory precats!
I've got a lead on a system coming off of a 96 LT4 that I believe I can make fit, which sounds very attractive. If that doesn't pan out, I will most likely go with either a full Magnaflow system from the manifold back, new high flow Magnaflow main cat and/or put an OEM replacement front Y w/precats and Magnaflow cat back. From what I've read this seems to be the best solution for what I'm looking for.
You can go to their web site to get the price. I also had the shop install a new O2 sensor that I got from a GM dealer. I then went back to Corvette Central and bought chrome ZR-1 tips for around $100. The system was perfect!
