Most reliable C4?
Fewest issues such as Opti, electronics, etc.
It would be tough to honestly say
...too many variables, as they are all USED cars now at this point.
Some will say the L98's are more reliable - the tried & true small block Gen I V8 Chevrolet w/ distributor - others will say an opti LT1/LT4 is just fine. Some may even say an LT5 is darn near bulletproof
The L98 motor is very strong, easily modded and is famous for it's low-end torque. The LT1 motor has more HP and a stock LT1 against a stock L98 is a close race with the LT1 being a bit faster on the top end. LT1's are capable of 30MPG on the freeway and even 15-17 in town is doable.
The OptiSpark in the LT1 can be a problem, but there are lots of LT1 motors running around that still have the original unit. My 92 that I just sold last summer is still running fine with the original Opti. They do not like being wet although the later (95-96) units had a vacuum line in them to keep moisture out.
Auto tranny cars use the GM 700R4 design are probably the best choice a they can handle lots of power and no worries with clutch wear or hydraulics. The ZF 6-speed (found in the 89 and later cars) is a strong tranny but can be very expensive to fix.
Coupes are good for the storage under the hatch but some exhibit lots of "cowl shake". Verts are fun but limited storage space behind the seats.
i did and i'm payin out the wazoo for it
That's a way bigger factor than what year it is.
better dash - that is an opinion
better brakes?? Than what? J55 was avail on most C4's
My point here - and from the begining, is that there is a lot of opinions about what is "better" however, where are the factual points in this thread?
...no disrespect meant - but without facts, the "newer has to be better" dosen't hold water...
After all, GM got cheap in 1990 when they discontnued the mass air sensor and went to speed density (at the expense of overall drivability).
Ive had both an '85 and now a '96. The overall condition of both was and are the same. The '96 is overall a better put together, better feeling and better equipped car,lmo. They are still alike in some ways, but in the overall drivability and quality, pluss durability (4+3 trans)? BTW the later models use both speed density and maf systems in conjuction, which is somewhat redundent but does not show GM's dropping the ball. (opti is ify though) Overall, 95,96 systems are still up to todays standards with 96's being obd 2 a little better. IMO.
So following is my opinion, which is not debatable, facts might be:
1. Better dash--I like the gauges and configuration, and don't see very many want to buys in the c4 parts sections for the newer dash clusters,
or tech help needed posts either. That is my opinion.
2. Starting in 95 the HD brakes, which were standard on the zr1 previously, were made standard. Even Gordon Kilebrew stated the earlier brakes left lot to be desired. That is my opinion.
3. With same model of vehicles continuous improvement processes are expected by the buying public. As problems in design, engineering, or production are rectified the product is expected to improve. That does not always happen, but is at least supposed to happen. That is my opinion.
All of the above is still secondary to buying the best for the least, and low mileage well maintained vehicles are much more desireable then newer hi mileage poorly maintained vehicles. That is my opinion.
If you really want low mileage and cheap look for a used Lincoln or Cadillac, not a Corvette. That is my opinion.
Take care and Enjoy the Ride
But otherwise I agree with ya.......
Having owned a '93 and now a '96 there IS a difference. One came to me with 0 miles and one with 7900. Close, and a cigar.
