Glass tops vs. Solid tops
Old May 20, 2006 | 10:32 PM
william.dempsey's Avatar
william.dempsey
Cruising
I have both tops, the glass one started cracking in the front left corner and was noisy and flexing alot, had the solid top painted and installed it and it's been on ever since, quieter and cooler, no more squeaks or flexing. I can change either one by myself without and problems.
Old May 20, 2006 | 11:02 PM
Storms of War's Avatar
Storms of War
8th Gear
Couldn't you guys have a lexan top fabricated? I was going to replace the glass in my Trans Am with this stuff (I decided against it)-
http://www.percyshp.com/producthomespeedglass.html
It would be easier to handle, plus you'd shed tons of weight off of your car.
Old May 20, 2006 | 11:11 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by j3studio
The glass top has more headroom for those of us of the taller persuasion...
My solid top's headliner was drooping as GM headliners are prone to do so I just peeled it out. I haven't used my clear top since I got the solid one and now it has just as much headroom when wearing my helmet. I figure my clear top didn't have a headliner so I can live w/o one in this top too.
Old May 29, 2006 | 12:28 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Originally Posted by Yellow92LT1
What is the weight difference between the two tops? I only have the solid top, it is a pain to take on and off very often. Is the glass top a bit easier to handle? I have looked at the raincoat, looks like the ultimate quick top, but I dont want to spend 300 bucks to find out if it will suit my needs.
What do you think?
glass top seems to weigh 1/2 that of solid top
It is due to that, the glass top is easier to handle
Old May 29, 2006 | 05:26 PM
NitrousSam's Avatar
NitrousSam
Painted solid tops are heavier than the clear so called glass tops.
Old Jun 20, 2006 | 03:24 AM
ol school's Avatar
ol school
Default Glass/solid
Originally Posted by JEFNLSA
The static sunscreen works great - I have the one w/ holes. I only have the clear top and see no reason to get the solid one...After I tinted the windows and added that baby even the Phx sun/heat is tolerable now. BIG DIFFERENCE!
I have both tops on a 96
The hard top works better ,the body is tied together and doesnt flex
as much, keeps interior cooler.
Smoke top has a lot of flex.Scratchs easily And is hotter n hell
in the summer.I put mine on by myself.I also had 70 model with t-tops
they sure went on and off alot easier.But just the same Solid for summer Glass for winter..
Old Jun 20, 2006 | 03:32 AM
JoeReckless's Avatar
JoeReckless
I have the glass top, but I only put it on when I have to wash the car. I know it is hot where I live, but I cannot seem to put it on ... ever...
The car looks so good without it.
