1991 Overheating Question?
Old May 12, 2006 | 12:44 PM
ken y2k c5's Avatar
ken y2k c5
Default 1991 Overheating Question?
We'll I'm back again. This time its on overheating. The 91 after driving for about 2 hours with or with out a/c starts to push 260 degree's. It hasn't complete overheated yet, I won't let it and it seems to stablize there, but it makes me nervous. I've always heard Vettes run hotter, but this seems way too much. Is there a problem and if so where should I start?
Ken
Old May 12, 2006 | 01:06 PM
RRT vette's Avatar
RRT vette
Have you changed fluid lately? If so did you burp the system? This could be a stuck thermostat, air in the system, fans not running, or if any leaks could be hoses, faulty waterpump, or leaky radiator to name a few.
Old May 12, 2006 | 01:28 PM
bsmutz's Avatar
bsmutz
Don't forget the dirt. Could just be accumulated muck in front of or in the fins of the radiator.
Old May 12, 2006 | 03:29 PM
84vette96's Avatar
84vette96
Are you looking at the analog gage or the digital ? My 96 made me nervus before I learned what the marks stood for.
Old May 12, 2006 | 03:32 PM
TA's Avatar
TA
No digital gauge on a 91 (unless aftermarket)
Old May 12, 2006 | 04:08 PM
84vette96's Avatar
84vette96
oops was not sure the year they put that in:o
Old May 12, 2006 | 04:25 PM
Red Tornado's Avatar
Red Tornado
my '90 has an HVAC digital readout.....coolant temp can be read by pushing the 2 buttons concurrently, at top, until "00" reads.....then push right button until "16" reads.....then push middle button for coolant temp in *C.
*F = *C X 1.8 + 32
dat dere izz the gig.
Old May 14, 2006 | 05:34 PM
JIMBO7's Avatar
JIMBO7
Default overheating??
I have an '88 coupe with 88k. I thought it was runnng too hot. If you haven't done the following yet, then have at it before changing anything.
1- clean between the radiator and in front of it. There was a load of stuff between mine. Plastic, leaves, leaves turning into compost, etc. You get the picture. I got a grabby entension thing at the dollar store and it made it a lot easier to clean out!
2- make sure you have full fluid. If you have air in the system, you'd get a lite on the dash. That happened when i changed coolent.
After this, I ran cooler but wanted more. I changed thermostat to 180
and fan sensor also. Haven't had any worries since.
Good luck
Old May 14, 2006 | 06:22 PM
CMYC4GO's Avatar
CMYC4GO
*F = *C X 1.8 + 32
Which buttons are you talking about???!!!!
Old May 14, 2006 | 07:28 PM
TA's Avatar
TA
Here's a tech tip that explains it.
https://www.corvetteforum.com/techti...=193&TopicID=2
Old May 14, 2006 | 09:27 PM
Big Willy's Avatar
Big Willy
We need more info. Is the coolant level ok? Are the fans coming on? Does the upper radiator hose heat up?
Old May 15, 2006 | 12:53 PM
ken y2k c5's Avatar
ken y2k c5
The fans come on and appear to be operating properly. The coolant is full and is clean (However I am planning on changing it anyway). After the temps rise for awhile I get a check engine light. It flashes code 32, which indicates an EGR problem. I hope this helps. I will check on the upper radiator hose. Thanks for everyones replys.
Old May 15, 2006 | 02:29 PM
pcolt94's Avatar
pcolt94
I think JIMBO7 has laid it out well. I stared running hot over a period of time, got hotter each month. Changed the thermostat on principal, really did not think it was bad. I was really thinking the radiator. It fixed me up. Heated in a pan of hot water and could see it was not opening properly. Do the cheep, easy most common thing first.
To 1991 Overheating Question?
