how do i add a pic to my post? i dont want to add a link to the pics. i know how to do that. i want my pic in the thread like others have. i do have a couple of pictures i need to post of two crank bearing caps i pulled today that dont look good. need advice.
picture link picture?C:\Documents and Settings\Steve Phillips\Desktop\picc\pics
this is the address on my pc where the pic is or the post above is where the pics are on my comcast account. seems iv left out my user name,password,dl,ss and gps.
Here are two threds with the links in them and details. To much for this post, just look at each. I have just started using photbucket myself.
I used the first post myself.
Go to your link. Right click on the image, then select properties, highlight the http://......... then paste that into your post with [img]http://......[/imgXXX] Do not use the XXX in your post, I put them there so the computer does not think I am tryin to post a picture.
It looks like you did not get all the address? The string you see that has the XXX at the end is the exact same string that I used to post the picture.Also don't forget the slash before the second '[/img]' If you look at the different forums you will find a test furom just to learn how to do this. If you want help send me a personal message and I will do my best to help you.
