DigiDash replacement options
Old Jun 6, 2006 | 12:54 AM
Albert C4's Avatar
Albert C4
Default DigiDash replacement options
My 88 vert's digidash has all the LCD's sunburned.
$$$ Repair!
What other type of dash can be used to replace the digidash? i.e. how hard to go to analog gauges?
How do I get the existing inputs (tach, fuel, speed, etc) to work with analogs?
Or am I stuck with $$$ repair?
Old Jun 6, 2006 | 01:03 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've never seen a 'bolt in' dash replacement, aside from the Dakota dash, (which is also digital, worse, and $1000).
Any of you electronics guys know how difficult it would be to put in electric autometer and scale up the signals if necessary from the existing harness?
The dash only receives signals, and has no effect on how the car runs, so a plug n play 'analog' dash sounds feasible on paper...
Old Jun 6, 2006 | 05:10 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Here is one that has been around for a long time:
Dash Conversion
To DigiDash replacement options
