I got to work this morning, and went to take the key out, turned it toward me, but it didn't turn quite as far as it normally does......and it won't turn far enought to line up with the 'lock' arrow on the column. Is there a special trick or button to get it to unlock? I jiggled the steering wheel, shift ****......nothing.....
I dont' really like leaving the keys in my car all day.....
Mine used to do that sometimes when the shifter button didn't pop all the way up. I took the console apart and cleaned the shifter up and the problem has gone away. Hope this helps.
I had a similar situation, all I had to do was jiggle the shifter (auto) so the button on top clicked into position all the way up, and the key could move to the lock position. Now it's a regular thing that I make sure that the shifter is fully into park and the shift button is all the way up.
It's in park, the button is popped up all the way on the shifter.........I just won't turn all the way. I really don't want to have to take this thing apart......
If you can turn it to start. start the car and move it backward/forward and try shifting into park again...
This worked for me...also seems like I almost always have to do the jiggle to insure button pops although after being very embarrased by not being able to remove key once I'm overly conscious of it.
I had already tried that as well.......any other ideas?
Pop it in neutral and try to remove the key. That use to happen to me on my caprice. The key probably wont come out in neutral but out of gear it loosened it up. Then try to push it in when turning back and then pull
spray some pbblaster on key and in igniton and cycle ignition a few times without starting it wipe up excess wait a few minutes and start car this is a normal pm i do on all our cars
My key gets stuck every once in a while. All I do is "slam" the shifter (auto) into park and the key will come out.
(In fact, I think I read about this trick on this forum.)
Every one is right.I just purchased my 96 and had the same problem.
Panic until I realize the shift button was still depressed.Bumping it back untill it poped out ,key came right out.
well the key is stuck again......this time, driving around and parking again isn't helping. If the ignition is off, and the car is in park, I shouldn't be able to turn the wheel much right? it should lock......but it feels like I could probably still sorta turn it if I really tried, but without the power steering help. This isn't cool. what should I try next?
Well from the best I can tell, it appears the lock cylinder might be the culprit. The only other thing I can think of is there should be some spray type graphite at the auto parts store you might try giving the lock cylinder a couple sprays and if you get the key out, give it another dose.
well Lani, I may have jinxed myself when someone on the forum asked: "what leaks on your vette", and I replied with "my eyes tend to leak a little every time I get near my car and have to pull out my wallet again"
I couldn't get the damn key out for anything, so I dropped it off at the shop today, and it's the shift-lock cable. I guess it's the linkage between the shifter and the ignition and it's broken. The part price wasn't bad...$60 including freight........it's the freakin labor. He quoted it at 5.9 hours (wierd number) which came to $582.37 for the labor.
So for now it seems, I'll be leaving the key in it. I'm just gonna take off any extra key rings and keys, and hopefully nobody will ever notice "hey theres a key in that empty vette there." The black part of the key showing, combined with the all black ignition and column and dash should camoflauge it pretty well. I can still lock the doors and get in though. I know it's not ideal, but it's getting to the point where every other month or so, it's $500 for this, and $600 for that, and I'm getting sick of it. A newer car is starting to creep into my thoughts.....
I understand your frustration. I go through the same things myself, seem like every weekend it is one thing or another and I never seem to get one foot ahead of it. A new vehicle (vette) is definitely on the horizon for me. Of course like all mechanical products there is no guarantee. Even brand new one's have problems and then you wait at the dealer for repairs.
I'm surprised you can lock it with the key still in there. That means once this cable is replaced you'll need to find out why the auto-unlock is not working, of course maybe the cable will fix that as well.
Maybe a couple bucks for one of those windshield blinds people stick inside their windshield will help deter anyone from seeing the key in there. I'll look for this in the FSM tonight to see what is the procedure and perhaps what are the issues with the installation.
Maybe it might be something you can do.
Oh yeah I dunno who made that post about leaks .... LOL
Dammit, you beat me to it. I just clicked on this thread but as you described your issue....especially the driving around the parking lot thing...I was thinking it's just the linkage. Some days you slammed it into park and everything was fine. The days you slowly moved into park the the key stuck......Linkage.
You should try to see where the cable hooks to the shifter. I'll bet there is a plastic piece that fits in there and it is worn enough to where that cable just does not move that last .020". new plastic piece may cure your ills. During this learning process you may even encounter an adjustment to tighten the linkage. Remember, you only need about .020" more to get that key lock to move.
