93 Keyless remote problem
Old Jun 9, 2006 | 11:05 AM
ewrobo's Avatar
ewrobo
Default 93 Keyless remote problem
A friend of mine purchased a 93 40th Anniversary vette about 2 months ago. He has just started having problems with his keyless remote. Last night His car wouldn't start and there was a clicking sound in the dash by the fusebox. I checked it out and after I put the key in the ignition a couple of times the clicking nosie stopped and the car would start right up. After walking away from the car the doors would lock and the clicking nosie would start again and the remote would not unlock the doors automatically. I would have to go through the same senerio to get the car to start. I went ahead and shut off the keyless entry per the instructions in the owners manual until I can get some help from the forum. A couple of days ago he put a new battery in his remote because it wouldn't unlock/lock the doors automatically.
Any suggestions on what might be causing this problem???
Many Thanks,
Eric
Old Jun 9, 2006 | 12:30 PM
Jet-Jock's Avatar
Jet-Jock
I'm guessing to first start at the car's battery and it's ground connections.
Ensure the connections are tight and clean (15Nm). Check all grounds.
Make sure the battery is up to par, a slightly weak battery will cause all kinds of problems. There are a series of relays along the knee pad. That's probably what you heard clicking. Insufficient battery power may be causing this.
Old Jun 9, 2006 | 12:38 PM
prcollin's Avatar
prcollin
I agree with the battery connections for i had the same problem. You may also want to check the striker button on the drivers side door and see if it is sticking. If it is I can give you a short way to lube it up.
Old Jun 9, 2006 | 12:45 PM
aminnich's Avatar
aminnich
The PKE would not keep it from starting. The VATS system does that.
Old Jun 9, 2006 | 12:53 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
My guess is that its both
Old Jun 9, 2006 | 02:06 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Change the battery in the remote if you have not done it.
To 93 Keyless remote problem
