Engine oil
Old Jun 11, 2006 | 03:24 PM
Kidvett's Avatar
Kidvett
Default Engine oil
Im about to change my oil in the vet still have to run out and buy it im gonan get mobil 1 full syn. just wondering what weight oil i should get 10w30 i would assume but i dont have the owners manuel so id like to know what u guys run. 92 auto 75k miles Thanks
Old Jun 11, 2006 | 03:49 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you know what weight has been run in it, I would stick with that. If not 10w-30 should be fine.
Old Jun 11, 2006 | 03:51 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Year of car?
Old Jun 11, 2006 | 03:58 PM
BADDUCK's Avatar
BADDUCK
92 auto
Old Jun 11, 2006 | 04:05 PM
Corvette Kid
Originally Posted by BADDUCK
92 auto
5w30 is the factory recommendation then but 10w30 should be okay in hot weather.
Old Jun 11, 2006 | 05:10 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
In every car/truck I've ever owned I use "Valvaline 20w50" and the large can of "Restore" (since it came out). I never had any problems
Old Jun 11, 2006 | 07:55 PM
Wayne88's Avatar
Wayne88
10W 30 is a little bit thicker and will be better for a high milage car, otherwise 5W 30 is good.
Either way its clean oil and better than the dirty oil.
Old Jun 12, 2006 | 07:44 AM
pcolt94's Avatar
pcolt94
I checked the book and fell into to 10W-30 catagory in Orlando. It cooks in the summer and not usually below 40 in winter, but with car in garage, at least 10* warmer. I might run the 5W-30 if I lived up north as I have. With 100K on the car I'm sticking where I am.
I do the oil every 6K. But I'm thinking of changing the filter at 3K because of the color of the oil. On regular cars I'm a 3K kind of guy. Best of luck. Charge on
Old Jun 12, 2006 | 07:55 AM
Aquaman92's Avatar
Aquaman92
I use 5w-30w Mobil one in my 92
Old Jun 12, 2006 | 10:17 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Both 5W-30 and 10W-30 will be at the same viscosity when the engine is up to operating temperatures. The 5W, of course, will be slightly thinner at start-up (cold engine), but unless you are parked in sub-zero temps at night, neither you nor the car will notice the difference.
I run 15W-50 in my vehicles without any problems...but it rarely hits freezing where I live.
Larry
code5coupe
To Engine oil
