86 vette stalled tonight
Old Jun 15, 2006 | 10:11 PM
86conv's Avatar
86conv
Default 86 vette stalled tonight
I have an 86 vette that while running tonight, temp reached 240 at an idle for an hour, just stalled on me. Motor has been rebuilt with no mods, new water pump, thermos stat, fans kicked on etc. I did smell some gas but there were no leaks under the car or on the motor. I also had the car on the lift the other day at the body shop and there were no leaks found there either.
I am assuming that the injectors could be the problem or am I wrong. I owned an 86 back in 87 and I smelled gas on that one too. Is this common?
Old Jun 16, 2006 | 09:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I wouldn't say it's common (gas smell). Have you done any diagnosing to see why it stalled ?? Does it start now ??
Old Jun 16, 2006 | 02:12 PM
86conv's Avatar
86conv
Car started back up within minutes which is why I am led to believe it might? be the injectors. Car has new plugs, wires etc... It certainly seemed odd.
Old Jun 16, 2006 | 04:50 PM
Blackhole's Avatar
Blackhole
If the ignition shut off you might get a gas smell from the unburned fuel. My 85 stalled after 1 1/2 hrs. on the road, was very warm but not hot. The distributor pick up coil magnet was cracked and made the spark intermitant- it would restart and run after an hour or so.
Old Jun 16, 2006 | 10:04 PM
86conv's Avatar
86conv
Dist is new also. But it did it again to me tonight. It happened when I stopped?
Old Jun 17, 2006 | 01:05 AM
RRT vette's Avatar
RRT vette
Well, get a fuel pressure guage on there and ohm the coils hot and cold. Should show or eliminate any doubts.
Old Jun 29, 2006 | 01:31 PM
86conv's Avatar
86conv
It was the cat conv., problem has been fixed. Thanks to all. Also, cleaned the injectors with Sea-foam and wella.....no more gas smell.
To 86 vette stalled tonight
