bending A-Arm back???
Old Jun 23, 2006 | 05:52 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Default bending A-Arm back???
i need help. i am redoing my suspension and i accidentally bent the lower A-Arm on the front left side. it is spread a little wider and now i need to bend it back about 1/6 of an inch for it to fit in the holes. any ideas. i have acess to regular home tools. .
i have tries to stick a rope through the new bushings with screwdrivers on the ends to hold it. then twisting the rope in the middle with a screwdriver to tighten it. it didnt work b/c i couldnt tighten it enough with out teh rope breaking.
Old Jun 23, 2006 | 06:13 PM
Pete K's Avatar
Pete K
A hydraulic press will bend it back. Are you sure you want to. A good used one would not be a bad idea.
Old Jun 23, 2006 | 06:19 PM
Midnite 88's Avatar
Midnite 88
with getting a good used one. The lower "A" arm is a heavily stressed part especially during spirited driving. While aluminum is a very soft metal, it doesn't take well to being bent and bent back.
I would be weary of a stress crack if you attempted to bend it back to try and make it fit.
Try Vette to Vette for a used replacement, or E-bay.
Old Jun 23, 2006 | 06:40 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
www.vette2vette.com is a good source. I've used them before with good results.
I would caution you against re bending the aluminum but if you're going to do it take it to a shop with a press and then insist on a die penitrant test to check for stress cracks.
Old Jun 23, 2006 | 07:14 PM
bogus's Avatar
bogus
took the words right outta my mouth.
Jason just got a nice 96 with rear damage... that has a perfect front on it.
Old Jun 23, 2006 | 07:15 PM
Grease Monkey
the bend is very slight and i highly doubt that it would cause a crack. i just cant figure a way t obend it the fraction of an inch back.
Old Jun 23, 2006 | 08:54 PM
bogus's Avatar
bogus
whew... I still think you are flirting with disaster...
Old Jun 23, 2006 | 09:16 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
A hydraulic press will do it, although it will probably bend the other arm in, so you'll have two bent arms and it will be a little off.
It probably won't be an issue, but it's ultimately your *** on the line.
Old Jun 23, 2006 | 09:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Maybe you could wedge it between something really solid and a floor jack.
Old Jun 23, 2006 | 10:45 PM
tonymax2's Avatar
tonymax2
The A arm is heat treated forged alum alloy (6061 I believe). This alloy, and most alum alloys will work harden rapidly when bent and rebending aggrevates the problem enormously. You're asking for trouble if you rebend it! Dye penetrant will not show how stressed the metal is. There may be no crack now but the metal may be hard enough that the next significant load impressed on it will push it into yield and it could snap. Try this experiment if you want to get an appreciation of work hardening-take a piece of 1" OD x .049" wall 6061T6 alum tubing
(pretty easy to find) and bend it around a 3" radius curved block of wood about 20 degrees. Then bend it back. With luck, you'll get about 5 degrees before it snaps like a pretzel! Bite the bullet and get a good used replacement part (and destroy the bent one so it doesn't get to someone else).
Old Jun 23, 2006 | 10:50 PM
CentralCoaster
I'm thinking because one end is now work hardened, when he tries to bend it back, it won't bend in the same spot.
Old Jun 24, 2006 | 10:23 PM
Grease Monkey
your talking a 20degree bend. im talking a 1 degree.
Old Jun 24, 2006 | 11:00 PM
ALLT4's Avatar
ALLT4
OK, the guy didn't ask if he should, he asked how. I'd get some threaded rod that just fits through the dam thing. Biggest you can fit. Get some huge washers (several on each end would be better) and crank a bit, back off and check, repeat until you measure a difference.
The idea is to not go too far, the things gonna act like giant freaking spring so I'd wear some eye protection and keep my face away.
I just envision pain somehow.
Old Jun 24, 2006 | 11:35 PM
bogus's Avatar
bogus
ALLT4 has a good suggestion... it's cheaper than the press, and just as effective.
Old Jun 25, 2006 | 12:29 AM
ALLT4's Avatar
ALLT4
Meh...where there's a will there's a way just like my freakin' hub right now. I will not spend $200.00 on a one time tool, I will not spend $200.00 on a one time tool, I will not spend $200.00 on a one time tool...
I'm swear I'm gonna have one of those "that's so simple why didn't I think of that" moments if I think about it hard enough.
I have some ideas right now but I need to check it tomorrow.
Old Jun 26, 2006 | 12:19 PM
Grease Monkey
i have them moments all the time
To bending A-Arm back???
