You might try your local electric/air tool repair shop.
I found a set of Bosch replacement motor brushes for my '92 there, but I had to sand them down with an emery cloth before they would seat properly in the armature holders.
I paid $8.70 for 1 set of motor brushes. The Bosch part number is 3604321509 if that helps.
thanks man this has been driving me nuts. i knew i should be able to get the parts myself just wasn't sure where to look.
try mid america motorworks lots of corvette stuff there
my mail box is full of their catalogs every other week unfortunately they don't carry the parts i need just the rebuilt motors. and they won't tell me where they get the motors rebuilt.
Was just wondering if anyone here knows where I could get a set of brushes for my headlight motor? Btw it's for an '84
Just go to Autozone and get the nylon bushing for to repair a ford windows they r the ones that are use in the vette. they cost about $4-5.00, I repaired mines about seven months ago. I order a set from Eckler and received enough for one headlight so I went to Autozone with the bushings and look at the nylon bushing under the windows repair section they r the one ford uses. Make sure u clean out all of the old bushing b4 installing them. Hope this is helpful
He said MOTOR BRUSHES not bushings. I steered him in the right direction, but thanks for your comments, too.
Early and late motors are completely different. There are no replacement parts available for the early motors. The brushes are part of the brush and limit switch assembly. The contacts and brushes are kind of like the old style points and how they attached to the arm. Some kind of cad welding or something. If this module was available, a lot of motors could be easily repaired. I don't know why someone hasn't done it yet. Maybe it's not cost effective. Anyway, try to find a used motor and salvage the parts. That's what all the rebuilders do. They make one out of several.
