crashed my corvette! :(
Basically spun the rear into a concrete wall and hit pretty squarely in the back bumper. The back 'bumper cover' is pretty well wasted. The lights to the left and right of the plate are gone and that whole panel is now hanging. There is minor damage to the drivers side panel where it now buckles above the wheel well. The driver's side door no longer wants to open.I need to investigate further just how bad the damage is- it actually drives pretty much the same as pre-crash, but this is bad. Especially considering that its my only car.
It does appear that the damage is pretty confined to the rear and back side panel, and that the frame and gas tank assembly isn't damaged, but I am taking it in to have all that confirmed.
I have been researching replacing these parts, and am reading that this is assmebled using a lot of adhesives, and that on the convertible, this whole area may be a single huge fiberglass shell. This is all making me want to just skip the whole thing and get a new car.
I'm looking for some opinions from folks who've been through this- just how much pain and suffering is this going to require?
Also, when describing what I need, I'd like to study up terminology, as in what is described by terms such as 'rear clip', 'bumper cover', 'rear bumper' etc? What years will share parts with a '92 convertible? Finally, to avoid huge shipping costs- does anyone know of a resource near charlotte, nc?
Thanks for any help! (and condolences)
-kevin
If no coverage, you're probably better off selling the car damaged and buying another one. Put it on eBay, and you'll get some interest. A lot of bodymen buy wrecked cars on eBay and fix them. They have the tools and the know how, and can do it without paying the labor, which is the most expensive component of body repair.
Sorry to hear you cracked it up.....we've all been there before. As long as you're not hurt, everything else is minor.
Good luck...
Mostly sounds like cosmetic damage....till I got to the part about the door not wanting to open....that's not good as the striker plate is attached to the upright on that side of the bird cage....so something moved during the impact. It could be something simple like the striker or the rear body panel moved into it. Look to see if the quarter moved into the door opening. If you can't find any body panels in the way to prevent the door from working then it's more than "sheet metal" related.
If you get the door open take measurements from the good door opening along the frame rail(sill) to the "B" pillar and along the top of the door to the "B"-pillar. I would guess the FSM might have key measurements for panel fit that may help determine if the "bird cage" moved....I don't know if that can be fixed in the "driveway" so to speak.
Good luck!
Depending on how severe, that advice about putting it up for sale the way it is may be a good idea, or not. If extensive damage, the parts won't be cheap, but he's right: the big money is still in the labor to get it on there right, prepped and painted.
But I'm hoping it's repairable for your use. Good luck and tell us how it turns out.
..and anyway as its a vert, there IS no rear hatch!
To update the rest of you, here's a clip from the other forum I read:
It appears that much of the fiberglass is a single composite structure. The jammed door is the apparent result of that rear quarter panel having shifted by about 1/16" to overlap the top edge of the driver's door. The driver's door is damaged only slightly (basically just a layer of paint) where the panel slid onto it locking it in. I nearly took a dremel and sliced that overlapping area off so that I could open the door this weekend, but couldn't bring myself to do it. I was thinking I might also just winch that panel backwards 1/16" now that I've removed the wheel wells. That should also free the door. Not yet sure which fasteners I might loosen to encourage that panel to slide. I'll try to post some pics later.
thanks again.
I'll take your ECM and rear hatch struts
if you have any further questions or need help feel free to PM me.
here is some pic's of the work that i did.
when i wrecked it
http://i46.photobucket.com/albums/f1...r/100_0367.jpgi know that it doesnt look bad but the 2 panels were trashed.
with the back removed
http://i46.photobucket.com/albums/f1...r/100_0393.jpg
i dont have one of me cutting the 1/4 panel but here is the new one glued on
http://i46.photobucket.com/albums/f1...r/000_0095.jpgmake sure that panel is on right so that the back will fit.
and here is it finished, now i just need paint
http://i46.photobucket.com/albums/f1...r/000_0091.jpg
WEAR A MASK WHEN CUTTING!!! there is a lot of dust
good luck
, btw it took me about 1/3 of the cost as the dealer was asking
I'd be crushed if that happened to my car. Good luck with the fix. Some folks will give ya some great advice here shortly.
