Somewhat doubt the cleaner has anything to do with it. Intermittent stalls are a challenge and often lead to a lot of new and unnecessary parts, so you might start by getting something to capture some data with. A basic scan will at least show you if it's rich or lean, but I've got a feeling it's losing an important signal somewhere - either air (MAF) or fuel - reference from the distributor and without that, the injectors won't fire so it stalls just like you turned the key off. For 30 Bucks, I would try a new Module, but get some data first. With that, you can also know if the idle is within specs which are +/- 50 rpms from Targeted in Drive; +/- 100 rpms in Park/Neutral.
I've used the stuff several times on different vehicles and have had no ill effects. It actually saved me from replacing an injector on my '98 Durango. It had a dead hole at idle and low rpms. No clickity-click sound coming from one injector. Dumped some cleaner in the fuel tank at fillup and it started hitting on all 8 again within 1/2 mile. Acted up again after next fill up without cleaner. Put in another one. Did that probably 3 times before the mis went away forever. Dumped one in my '87 vette with no ill effects.
$75. heck the filter is only about $10. even if you bought the line wrench..another $10. a set of ramps $45. and a 20 minute job. Why not do it yourself.
thanks for all the replies, i'm went today to get the fuel filter changed but it was $75 and i only had like $85 to my name, so i'm going to wait until i get paid again.
i know that the injection cleaner might be a coincedence, but i mean it did it the very first time like 5 minutes after i put it in, thats why i figured it must have been the injection cleaner, it seems like it was just to close to be a coincedence.
the car runs fine when i keep the rpm's up over 1000, it's just when i'm going slow or at a light or something and it's idling that it shuts off.
Please don't take this as demeaning or condesending...You are going to have to learn to wrench on that girl of yours at some point. That being said, the filters are not all that difficult to do and are going to be a recurring maintenence item for you to handle. Lots of money is wasted sending cars to shops for doable items...Let the experts handle the jobs that are too difficult. Every minute you spend with your service manual is money saved for other things. Lecture over. Good luck, Larry
